查看: 3672|回复: 2
[求助] 仿真时的一个错误
发表于 2011-4-5 22:11:48 | 显示全部楼层 |阅读模式
我在进入仿真是有错误提示:** Error: Failure to checkout svverification license feature.
# Unable to check out verification license required for SystemVerilog Assertions. SVA concurrent assertions are disabled.
在仿真中会因错误而停止仿真,提示的错误代码为:assert(op.randomize());
# OVM-2.1.1
# (C) 2007-2009 Mentor Graphics Corporation
# (C) 2007-2009 Cadence Design Systems, Inc.
# ** Error: Failure to checkout svverification license feature.
# ** Fatal: generator.sv(34): Unable to check out verification license for randomize() feature.
#    Time: 180 ns  Iteration: 1  Process: /top/#FORK#65_7f5b9ca File: generator.sv
# Fatal error in Task run at generator.sv line 34
不知道这是不是Questa6.6d的原因?
发表于 2011-4-6 15:57:55 | 显示全部楼层
怎么都不看提示的?你的lic feature不全。验证环境有sv的assertion没有授权。
 楼主| 发表于 2011-4-6 20:26:09 | 显示全部楼层
问题解决了是Questa额license问题。重新安装一下就好了。估计是之前安装HDL的原因。
GMT+8, 2025-12-21 14:47 , Processed in 0.022391 second(s), 6 queries , Gzip On, Redis On.
