查看: 5550|回复: 7
[求助] 想请问如何找到EDA后端布局布线的工具,比如soc encounter之类
发表于 2011-3-31 18:57:45 | 显示全部楼层 |阅读模式
 楼主| 发表于 2011-3-31 19:00:10 | 显示全部楼层
因为许多是不公开的,要买。。。
哪位知道如何破解?
发表于 2011-4-1 09:46:57 | 显示全部楼层
 楼主| 发表于 2011-4-1 14:22:29 | 显示全部楼层
回复 3# wys093
    thanks!
发表于 2011-4-2 18:28:04 | 显示全部楼层
正是我所需要的 ,谢谢分享!!!!
 楼主| 发表于 2011-6-28 19:56:34 | 显示全部楼层
回复 3# wys093
hello  .I met some error when I execute the "patch_encounter3264 "file :
how can I fix it ?
    # ./patch_encounter3264
[total hits/matching patterns/non-matching patterns]
63% extwarn : empty file: perl/lib/5.8.0/i686-linux/auto/B/C/C.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/B/B.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/ByteLoader/ByteLoader.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Cwd/Cwd.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Data/Dumper/Dumper.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Devel/DProf/DProf.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Devel/PPPort/PPPort.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Devel/Peek/Peek.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Digest/MD5/MD5.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/Byte/Byte.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/CN/CN.bs - skipping
03% perl/liwarn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/EBCDIC/EBCDIC.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/JP/JP.bs - skipping
                                                            warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/KR/KR.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/Symbol/Symbol.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/TW/TW.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/Unicode/Unicode.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Encode/Encode.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Fcntl/Fcntl.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/File/Glob/Glob.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Filter/Util/Call/Call.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/GDBM_File/GDBM_File.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/I18N/Langinfo/Langinfo.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/IO/IO.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/IPC/SysV/SysV.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/List/Util/Util.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/MIME/Base64/Base64.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/NDBM_File/NDBM_File.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/ODBM_File/ODBM_File.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Opcode/Opcode.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/POSIX/POSIX.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/PerlIO/encoding/encoding.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/PerlIO/scalar/scalar.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/PerlIO/via/via.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/SDBM_File/SDBM_File.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Socket/Socket.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Storable/Storable.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Sys/Hostname/Hostname.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Sys/Syslog/Syslog.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Time/HiRes/HiRes.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/Unicode/Normalize/Normalize.bs - skipping
83% ...lib/5.8.0/i686-linux/auto/Unicodwarn : empty file: perl/lib/5.8.0/i686-linux/auto/XS/APItest/APItest.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/XS/Typemap/Typemap.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/attrs/attrs.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/re/re.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/threads/shared/shared.bs - skipping
warn : empty file: perl/lib/5.8.0/i686-linux/auto/threads/threads.bs - skipping
69% perl-5.8.8/lib/5.8.8/i686-linux/Config.pod : 0 warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/B/B.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/B/C/C.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/ByteLoader/ByteLoader.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Cwd/Cwd.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Data/Dumper/Dumper.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Devel/DProf/DProf.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Devel/PPPort/PPPort.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Devel/Peek/Peek.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Digest/MD5/MD5.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/Encode.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/Byte/Byte.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/CN/CN.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/EBCDIC/EBCDIC.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/JP/JP.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/KR/KR.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/Symbol/Symbol.bs - skipping
13% perl-5.8.8/lib/5.8.8/i686-linux/autowarn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/TW/TW.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Encode/Unicode/Unicode.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Fcntl/Fcntl.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/File/Glob/Glob.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Filter/Util/Call/Call.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/GDBM_File/GDBM_File.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/I18N/Langinfo/Langinfo.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/IO/IO.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/IPC/SysV/SysV.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/List/Util/Util.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/MIME/Base64/Base64.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/NDBM_File/NDBM_File.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Opcode/Opcode.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/POSIX/POSIX.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/PerlIO/encoding/encoding.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/PerlIO/scalar/scalar.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/PerlIO/via/via.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/SDBM_File/SDBM_File.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Socket/Socket.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Storable/Storable.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Sys/Hostname/Hostname.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Sys/Syslog/Syslog.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Time/HiRes/HiRes.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/Unicode/Normalize/Normalize.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/XS/APItest/APItest.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/XS/Typemap/Typemap.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/attrs/attrs.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/re/re.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/threads/threads.bs - skipping
warn : empty file: perl-5.8.8/lib/5.8.8/i686-linux/auto/threads/shared/shared.bs - skipping
                                                  error: failed to read+write: sfk - skipping
warn : cannot read:
18043 files checked, 0 changed.
1 errors, 94 warnings occurred.
发表于 2011-8-14 23:41:08 | 显示全部楼层
SSSSSSSSSSSSSSSSSSSSSSS thank you !
 楼主| 发表于 2012-10-19 20:12:05 | 显示全部楼层
回复 7# sjx
    http://bbs.eetop.cn/thread-356390-1-1.html
EDI 11.1下载!
GMT+8, 2025-12-17 00:27 , Processed in 0.018713 second(s), 6 queries , Gzip On, Redis On.
