查看: 2129|回复: 2
[求助] LNA matching network
发表于 2011-3-31 15:59:13 | 显示全部楼层 |阅读模式
小辈再做一个60GH的LNA,大概分三级实现指标,S21>15dB,S11,S22<-10dB,S12<-20dB.NF<8dB,IIP3>-15dBm,Power consumption <40mW. 目前,在做第一级电路,想用cascode 连接方式,这样隔离度比较好。两个nmos 管子间怎样连接,中间需不需要加原件,在cadence里有微带线和短截线怎样实现 输入端折中匹配(使噪声降低,也不至于Gain 太小)和输出端的共轭匹配。
发表于 2011-3-31 23:43:24 | 显示全部楼层
回复 1# Aileys
    Remember you are designing IC not PCB. I don't think transmission line effect is prominent even though the frequency is high as 60GHz. Pay more attention to all kinds of coupling.
 楼主| 发表于 2011-4-1 10:20:56 | 显示全部楼层
回复 2# hezudao
    As you say "pay more attention on coupling", How can I do it at first(or as the starting point)
GMT+8, 2025-12-21 18:33 , Processed in 0.017349 second(s), 5 queries , Gzip On, Redis On.
