查看: 3679|回复: 0
[求助] DSP Builder中Error (10481)
发表于 2011-3-22 18:13:40 | 显示全部楼层 |阅读模式
手头有一块DSP Development Board开发板,安装了的Quartus II是6.0的,版本很老,还装了DSP Builder 和 Video and Image Processing Suite,在使用DSP Builder 完成Altera提供的Examples\Video_IP_Example_Design\example_design_data_path过程中遇到了问题,能够顺利的convert MDL to VHDL,但是在执行Synthesis出现了以下的错误
Error (10481): VHDL Use Clause error at chroma_resampler_v1_0_0_crs.vhd(4): design library "work" does not contain primary unit "ALT_CUSP_PACKAGE" File:/Altera/kits/Examples/Video_IP_Example_Design/example_design_data_path/chroma_resampler_v1_0_0_crs.vhd Line: 4
Error: Node instance "chroma_resampler_v1_0_0_crs_inst" instantiates undefined entity "chroma_resampler_v1_0_0_crs" File: D:/Altera/kits/Examples/Video_IP_Example_Design/example_design_data_path/chroma_resampler_v1_0_0.vhd Line: 71
大意是chroma_resampler_v1_0_0_crs.vhd 没有包含ALT_CUSP_PACKAGE,打开chroma_resampler_v1_0_0_crs.vhd,里面的内容全是乱码
不知道这个是什么问题,哪位大侠能帮忙解决下啊,万分感激
GMT+8, 2025-12-25 20:11 , Processed in 0.018140 second(s), 7 queries , Gzip On, Redis On.
