查看: 2812|回复: 4
[求助] incremental是什么意思
发表于 2011-3-19 22:26:16 | 显示全部楼层 |阅读模式
encounter中preCTS时incremental opt是什么意思?望高手指教。
发表于 2011-3-20 22:37:54 | 显示全部楼层
-incr has the following limitations:
■ You cannot use it if you also specify -si or -drv.
■ Without it, optDesign does not run when a path group
other than register-to-register is selected.
■ You must have already run optDesign on all path groups
before running it with -incr.
发表于 2011-3-21 10:23:32 | 显示全部楼层
学习了
 楼主| 发表于 2011-3-22 12:24:21 | 显示全部楼层
回复 3# yangzhuli
    多谢指教
GMT+8, 2025-12-28 11:45 , Processed in 0.014947 second(s), 5 queries , Gzip On, Redis On.
