查看: 3990|回复: 15
[资料] CMOS AUTO-RANGING PLL INTEGRATED CIRCUITS FOR FREQUENCY SYNTHESIZERS
发表于 2011-3-16 08:45:44 | 显示全部楼层 |阅读模式
CMOS AUTO-RANGING PHASE-LOCKED LOOP INTEGRATED CIRCUITS FOR
FREQUENCY SYNTHESIZERS AND CLOCK RECOVERY CIRCUITS
by
Yi-Cheng Chang
TABLE OF CONTENTS
LIST OF TABLES ........................................................................................................... viii
LIST OF FIGURES ........................................................................................................... ix
CHAPTER 1 INTRODUCTION ........................................................................................ 1
CHAPTER 2 BASIC CONCEPTS OF PHASE-LOCKED LOOP CIRCUITS ................. 6
2.1. Design of an Analog Phase-Locked Loop ................................................................... 6
2.2. Design ofa Digital (Charge-Pump) Phase-Locked Loop .......................................... 15
CHAPTER 3 BUILDING BLOCKS FOR PLLS ............................................................. 20
3.1. The Typical PLL Circuit. ........................................................................................... 20
3.2. Current-Controlled OscillatorNoltage-Controlled Oscillator (CCONCO) .............. 21
3.2.1. Tuned oscillators ..................................................................................................... 21
3.2.2. Relaxation oscillat .............................................................................................. 23
3.2.3. Ring oscillators .................................................................................................. 24
3.3. D flip-flops and frequency dividers ........................................................................... 28
3.3.1. ECL type D flip-flops ........................................................................................ 28
3.3.2. Dynamic D flip-flops, and T flip-flops .............................................................. 32
3.4. Phase/frequency detectors .......................................................................................... 33
3.4.1. Tri-state phase-frequency detectors ................................................................... 34
3.4.2. Hogge's Phase detectors for clock recovery circuits ......................................... 36
3.5. Rotational frequency detector .......................................................................... , ......... 37
3.6. Differential charge-pump and the second order low-pass filter ................................. 41
3.7. Signal control circuit of the CCO .............................................................................. 42
3.8. Design of the PLL IC layout. ..................................................................................... 44
CHAPTER 4 HISTORICAL REVIEW OF AUTO-RANGING PLLS ............................ 46
4.1. Prior auto-ranging frequency synthesizer by Basset ................................................. 46
4.2. Prior Auto-ranging PLL circuit by Worden .............................................................. 50
4.3. Prior auto-ranging clock recovery circuit by Baumert ............................................. 53
4.4. Prior auto-ranging clock recovery circuit by Park .................................................... 55
CHAPTER 5 DESIGN OF AUTO-RANGING PLL FREQUENCY SYNTHESIZERS 59
5.1. Circuit Design ............................................................................................................ 64
5.1.1. Signal control circuit of the CCO .................................................................... 65
5.1.2. Coarse-steering frequency comparators ............................................................ 68
5.1.2.1. Approach using full-adders ............................................................................ 68
5.1.2.2. Approach using an UP/DOWN counter ......................................................... 71
5.2. Simulation Results ..................................................................................................... 75
5.3. Consideration of the IC layout.. ................................................................................. 81
5.4.. Compa'ns ons to pn.o r art .............................................. ............................... ..... ....... ... 8_/
CHAPTER 6 DESIGN OF THE AUTO-RANGING PLL FOR CLOCK RECOVERY
CIRCUITS ........................................................................................................................ 88
6.1. Bit-rate estimators and pulse-width comparators ...................................................... 90
6.1.1. Proposed bit-rate estimator ................................................................................ 94
6.1.2. Proposed pulse-width comparators .................................................................. 103
6.2. Range-selecting circuit ............................................................................................. 107
6.3. Simulation for the overall auto-ranging CRC .......................................................... III
CHAPTER 7 IC FABRICATION AND TESTING ....................................................... 113
7.1.Single-loop PLL IC ................................................................................................... 113
7. 1.1 . Open-loop oscillator testing setup ................................................................... 114
7.1.2. Closed-loop PLL circuit testing ....................................................................... 116
7.1.3. Single-loop PLL chip micrograph ................................................................... 123
7.2. Auto-ranging PLL IC ............................................................................................... 123
7. _., . 1. T·I me da mai. n c h·I p testi.n g ................................................................................ 1'_J )-
7.2.2. PLL output spectrum testing ........................................................................... 130
7.2.3. Power consumption of the auto-ranging PLL circuit ...................................... 133
7.2.4. Chip micrograph for the auto-ranging PLL IC ............................................... 134
7.3. Summary of the experimental results ..................................................................... 135
CHAPTER 8 CONCLUSIONS ..................................................................................... 136
REFERENCES ............................................................................................................... 138
l
CMOS auto-ranging PLL integrated circuits for frequency synthesizers.pdf
1.91 MB, 下载次数: 120 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-3-16 09:28:17 | 显示全部楼层
非常感谢
发表于 2011-3-16 09:46:07 | 显示全部楼层
好,谢谢楼主的分享
发表于 2011-3-16 09:51:34 | 显示全部楼层
2000年的专题论文,希望没过时
发表于 2011-3-16 10:16:10 | 显示全部楼层
好,谢谢楼主的分享
发表于 2011-3-16 11:27:48 | 显示全部楼层
我来学习一下
发表于 2011-3-16 11:38:11 | 显示全部楼层
Thanks
发表于 2011-3-16 11:50:03 | 显示全部楼层
good reference
发表于 2011-3-16 17:41:55 | 显示全部楼层
thanks for sharing
发表于 2011-3-16 19:32:05 | 显示全部楼层
非常感谢
GMT+8, 2025-12-25 09:18 , Processed in 0.021165 second(s), 5 queries , Gzip On, Redis On.
