查看: 5927|回复: 6
[讨论] jitter dithering 区别??
发表于 2011-3-12 23:51:35 | 显示全部楼层 |阅读模式
大侠们能解释这两者区别和联系吗?
发表于 2011-3-13 15:31:30 | 显示全部楼层
jitter is the random noise on the clock signal. in the frequency domain, jitter is equivalent to the phase noise.
dither is the technique that adds white noise onto something, usually is quantizer, to make it more linear. dither sometimes is used in Sigma-Delta ADCs to remove the idle tones.
 楼主| 发表于 2011-3-13 16:14:25 | 显示全部楼层
thanks.
发表于 2011-5-12 09:24:19 | 显示全部楼层
一楼所言即是啊
发表于 2011-5-12 12:56:58 | 显示全部楼层
对象不一样,不是表征一个东西的。
发表于 2014-7-7 09:59:38 | 显示全部楼层
白噪声,加上之后呢?
发表于 2023-3-6 13:54:35 | 显示全部楼层
sdmout 发表于 2011-3-13 15:31
jitter is the random noise on the clock signal. in the frequency domain, jitter is equivalent to the ...
什么是idle tones呢?
GMT+8, 2025-12-28 11:45 , Processed in 0.018367 second(s), 5 queries , Gzip On, Redis On.
