楼主: sdust.wwk
[求助] 请教cadence ELc(encounter libaray character)问题
发表于 2015-9-29 01:31:36 | 显示全部楼层
Hi, I encountered the exact same problem, but got to fixed it after some struggling. I figure it is better to have it documented here.
Actually it is the model file, check if your model file is in the spice format. If so, convert it to the spectre format. In my case, ELC was running without problem after I convert the model file using
spp   -convert   <model.spice>   model.spectre
Help it can help someone, someday.
发表于 2018-6-24 20:41:33 | 显示全部楼层
在网表顶层加上电源地的pin试试
GMT+8, 2025-10-8 07:11 , Processed in 0.026708 second(s), 5 queries , Gzip On, Redis On.
