查看: 7236|回复: 4
[招聘] 【招聘】全球著名IC公司LSI上海研发中心热招
发表于 2011-2-25 16:51:33 | 显示全部楼层 |阅读模式
LSI公司简介-上海研发中心位于徐汇区徐汇苑大厦,深圳办公室位于帝国大厦
LSI公司成立于1981年,总部设在美国硅谷。LSI在全球拥有5000多名员工,在20几个国家和地区设有分公司,在中国拥有上海、北京、深圳、香港、台湾等分支机构。拥有强大的产品研发、销售、市场、技术服务队伍。LSI公司是创新芯片、系统和软件技术的领先供应商,采用LSI技术的产品可以使消费者与信息及数码内容之间无缝的融合。
公司在众多领域提供产品和服务,包括定制标准芯片、适配器、系统和软件。我们的产品已经获得众多世界级知名品牌的信任,为存储和网络市场提供了许多领先的解决方案。
欢迎有志之士加入!如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.也可加我msn;zql975504@hotmail.com
有意者,请将简历发至:Tracey.zheng@lsi.com
1.
Preamp Analog/Mixed Signal Design Engineer-Shanghai
JOB DESCRIPTION:
- Design high speed analog and mixed-signal integrated circuits within custom chips for the
hard disk drive industry
- Work directly with customers to determine system requirements, write specifications and
guide customers in the use of pre-amplifier products
- Use high speed electronic characterization equipment to evaluate and debug the
functionality of the design once the part is fabricated in silicon
- Provide technical leadership through all phases of product development including test,
yield, characterization, reliability analysis, qualification and release to manufacturing
PREFERRED EXPERIENCE:
LSI's Storage Peripherals Group is looking for an experienced custom analog IC designer to
join the pre-amplifier design team. At LSI we are committed to innovation and industry
leadership. We develop advanced high-speed magneto electronic read/write IC architectures
as the basis for our products.
Design team members define, create and modify high-speed custom integrated circuits for
hard disk drive (HDD) products using leading edge CMOS and SiGe BiCMOS technologies.
Team members support the entire product life cycle beginning with design and moving through
test, qualification, release to production and ramp to volume.
- Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
- Minimum three to five years experience in discrete, transistor level analog circuit design
- Experience with analog and mixed signal IC product design, integration and verification is
required
- Strong physical layout knowledge and parasitic component understanding essential
- Process and device physics knowledge critical
- Proven skills using electronic measurement equipment in a lab environment
- Expertise in applied magnetism and recording a strong plus
2.
Digital IC Design Engineer-Shanghai
JOB DESCRIPTION:
- Working with an Architecture/Algorithm Development Team to finalize system architecture
for optimal implementation of digital signal processing algorithms, including architectural
definition and tradeoffs, die size estimation.
- Digital logic design, verilog coding, logic synthesis, both RTL and gate level verification,
formal verification and static timing analysis.
- Perform some transistor level high speed digital integrated circuit design various cells and
blocks within custom chips for the hard disk drive industry. Examples of cells and blocks
include multiplexors, adders, multipliers, dividers, specific functional macro blocks,
- Work very closely with physical design engineers from floorplan through final parasitic
extraction to ensure smallest area and highest performance possible.
- Communicate effectively within a global business environment (must be proficient in both
spoken and written English)
- Experience in logic design, synthesis, static timing analysis, and verification
- Experience with ASIC EDA tools used in synthesis, simulation, static timing analysis, and
formal verification
- Experience in developing simulation and verification test benches
- Knowledge of Verilog/VHDL design languages
- Excellent technical troubleshooting and demonstrated problem solving skills
- Must be willing to follow a structured design approach including design for reuse and
provide thorough design documentation
3.
Read Channel Verification Engineer-Shanghai
JOB DESCRIPTION:
As a member of the Read Channel team, candidate must be willing to work as an extended
member of the design team. Duties will include functional verification of Storage read
channel mixed-signal IP. Candidate will be expected to contribute to design and development
of System Verilog based verification environment and will be responsible for verification
closure of block/chip/system level functions for mixed signal based IP. Experience with
System Verilog and functional coverage methodologies are required. Must be willing to
follow a disciplined verification methodology and to work closely with a multi-location,
international design team. Excellent teamwork and communication skills are required.
BSEE with 3-5+ years of design and/or verification experience required, MSEE preferred.
Required knowledge and skills:
- Expertise in System Verilog required
- Good understanding of Digital Signal Processing
- Good understanding of Analog and Digital Circuits
- Very good analytical/debugging skill
- Good verbal and written communication skills
Desirable skills:
- Knowledge of Verilog-AMS, Perl
- Knowledge of verification methodologies including functional coverage and constrained
random testing
- Knowledge of VLSI design flows & DFT
- Familiarity of high level programming language
- Experience working with globally distributed team management
- Experience in Supervising and mentoring Validation engineers
4.
Senior Debug Engineer –Shanghai
(注意:此职位只考虑应届博士生!!!)
JOB DESCRIPTION:
LSI Corporation is a leading provider of innovative silicon, systems and software technologies that enable products which seamlessly bring people, information and digital content together.
This position is part of the LSI's world-lead head-to-host recording system design validation team, and focus on high speed pre-amplifier validation PCB design. The tasks include: perform PCB design & layout process (starting from schematics level to bring the layout to final completion of checking LVS and DRC), manufacture support, debugging of the PCB board, and basic high speed test.
· Demonstrated ability to design controlled impedance paths for high speed signal(single and differential, 4GHZ +) including tapping to chip unit for lineout.
· Good hands on knowledge of Altium tools. Experience with PCAD or Cadence Allegro design tool is also desired. And circuit analysis simulation tool in signal integrity is a plus.
· Deep understanding of manufacturing, flip chip soldering and mounting processes for PCB
· Fundamental knowledge on high speed test knowledge (e.g. TDR, s-parameter, De-Embedding methodology), transmission line theory and circuit analysis is required.
· Proven skills using electronic measurement equipment in a lab environment
· Expertise in applied magnetism and recording a strong plus
· Good oral and written communications in English skills are required
5.
ASIC Customer Engineer-Shanghai
The Customer Design Engineer is a challenging and cutting-edge position working with LSI
internal methodology and foundation IP development teams to support complex ASIC designs
for either external tier one customers or internal ASSP programs.
As an integral member of the customer design engineering team, the ASIC Customer Engineer
has responsibility for a wide range of tasks, including chip floor planning, place and route,
timing analysis, signal integrity, test, and design verification.
Responsible for support and completion of designs from customer provided RTL or Gate level
netlist using the latest LSI technologies.
Design completion tasks include
- Presales Support (die size support, memory generation, address customer questions and
concerns.)
- RTL Analysis & Synthesis
- Physical Design Implementation (bonding, floor planning, power structure insertion, place
and route, timing closure) using Synopsys Astro or ICC tools
- Test insertion using Mentor, LogicVision, or Virage tools
- Formal Verification (Verplex or Formality)
- Static Timing Analysis (Primetime and Primetime SI)
- Cross talk analysis
- Power verification
- DRC & LVS
Overtime, all ASIC customer engineers within the design center are expected to develop the
skills to be able to do most of the tasks described above in this role. Candidates having strong
skill sets one or more of the following areas should apply:
RTL Analysis/Synthesis/STA: The ideal candidate should have strong skills for the front-end of
design implementation which includes RTL Analysis, Synthesis Strategies, and STA setup for
complex ASIC environments. This would include strategies for power management.
or
Physical Design Implementation: The ideal candidate should be strong in either the Physical
Design which includes floor planning, design closure, & STA. Having strong DRC & LVS skills
are a plus. Strong Synopsys Astro/ICC experience a plus. Having strong Mentor Calibre skills
a plus.
or
5+ years experience in ASIC design and implementation. Familiar with Verilog RTL coding,
Verilog Simulators (NC or VCS) , Synopsys Design Compiler, Synopsys ICC Physical design
tools, PrimeTime for Static Timing Analysis, Mentor FastScan, LogicVision, Verplex (or
Formality), and scripting. The ideal candidate should have completed at least one successful
ASIC or ASSP tapeout. Successful tape out using Synopsys Astro or ICC considered a strong
plus. Experience in working with customers desired. Experience in working with and
debugging prototypes considered a strong plus. Knowledge and hands on use of test insertion
/ vector generation / verification a plus. Some experience with Signal integrity a bonus. Must
possess excellent communication skills; be able to effectively communicate with other
members of the design team, supporting organizations, and management.
Education/Certifications
BS/MS Electrical, Computer Engineering or Equivalent.
6System Applications Engineer -Shanghai
Job Description
This is a Software Systems Applications Engineering position that involves the development and support of reference applications and API/FPI software for our customers. Software development includes creation of applications software for LSI multicore processor configurations using runtime API software, development of data path processing and forwarding software. Software support includes providing technical help on integrating LSI supplied application software with customer systems, LSI supplied SDE (Software Development Environment), reviewing customer application code, creating debugger APIs, simulator maintenance, and contributing to system software API testing. Customer interaction includes both pre-sales activities and issue debugging during development phases. Ability to work well with a variety of people and disciplines is required. Travel to customer sites is expected. Excellent communications skills in both Chinese and English are required
Requirements/Qualifications (Education)
- Minimum of 5 years software Engineering experience in a data networking or telecom product development. Focused on multicore processor microcode and API device driver with C on RTOS(Linux, VxWorks)
- Familiar with network architectures and applications, traffic management and resource management algorithms and function
- Knowledge of multicore processor and wireline (ATM, TCP/IP, MPLS, PPP, Gigabit/Fast Ethernet), wireless (NodeB, RNC, GGSN) networking protocols
- Familiar with Linux and VxWorks OS
- Excellent problem solving and communication skills
- Experience with writing documents (data-sheet, application-notes, etc.)
Desired: - software/hardware experience in Network Processor and/or multicore processor, e.g. PowerPC - customer support experience - knowledge of interface,e.g. PCI-E bus, GE, RapidIO Education/Certifications Required Degree: BS Preferred Degree: MS Preferred Major: MSEE or MSCS
7 Wireless System Architect-Shanghai
Job Description
- Project management, DOE, 6Sigma
8.
Program Manager
JOB DESCRIPTION:
Scope of programs:
- International Programs with contributors from several organizations and/or Business Units
- Programs with high business impact, above $20Mio total over product lifetime
- Programs with high development cost and effort, above 5 man years
- Programs with concurrent engineering of customer product and IP customization
Project Definition:
- Ensure that Goals, Objectives & Scope for the Program is defined, understood and agreed
to
- Work with engineering and management to form the project team.
- Develop a Project Plan with clear ownership and deliverables milestones together with LSI
and Customer teams
- Work with engineering to calculate and forecast the effort and investment for successful
project execution
- Drive concurrent Risk Management as integral part of the project planning and execution
Project Execution:
- Call regular project review meetings, internal and with the customer. Coordinate and align
the customer execution with internal LSI organizations and deliverables.
- Ensure effective communication between all parties involved. Provide regular project
reports (to the customer and internal)
- Continuously track/maintain and measure project schedule progress against plan
- Perform continuous Risk Management and elevate critical issues and risks.
- Manage the Change Management Process (with the customer and internal to LSI)
- Manage the Action Management Process
- Facilitate Project Lessons Learned (internal and with the customer)
- Minimum 5 years experience in the fields of management, sales/marketing and
engineering
- Good understanding of the ASIC design process & methodology
- Detailed knowledge of project management methodology, processes and tools (PMI
certification is a plus)
- Expert knowledge in Microsoft Project, Excel, and Outlook
- Basic knowledge in Microsoft Word and PowerPoint
- Engineering degree or equivalent
- Ability to adopt and execute a structured working methodology
- Fluent verbal and writing language skills in native language and English
- Strong communication skills
- Excellent interpersonal and leadership skills
- Self motivated and self driving
9.
Sales Account Manager-Shanghai
Job Description
1. Identify and develop new opportunity as well as manage existing business in global accounts,
implement sales strategies to achieve design win and revenue goals;
2. Aggressively promote LSI networking products to global accounts to drive
strategic design wins and build strategic partnership;
3. Communicate with internal team and customer closely to resolve commercial, technical,
quality, and delivery issues to satisfy customer expectation;
4. Establish and maintain good relationship with customer R&D, marketing and procurement
team;
5. Get visibility on customer market dynamic and manage booking and billing forecast
accordingly.
Specific Knowledge/Experience
1. Bachelor Degree at E.E, and M.S. Degree preferred;
2. Minimum 5 years' working experience in Semiconductor/Telecom sales;
3. Good communication skill, good at spoken and written English;
4. Be willing to work aggressively, passionately and diligently to achieve challenging goal;
5. It’s preferred to support Huawei before.
10.
Field Application Engineer__DSP -Shanghai
Job Description
- Work closely with Sales and customers to provide excellent support of new and existing business, including pre-design win and post design win.
- Achieve design wins at customers
- Support customers on-site when needed.
- Work closely with global technical colleagues (USA, China) to provide backup support.
- Track issues and defects and drive to resolution.
- Provide quick response to key customer’s request on technical support.
- Provide technical training to Sales team and customers
- Provide technical training to Sales team and customers.
11.
Field Application Engineer-Shenzhen
Job Description
• Work closely with Sales and customers to provide excellent support of new and existing
• Achieve design wins at customers
• Support customers on-site when needed.
• Work closely with global technical colleagues (USA, China) to provide backup support.
• Track issues and defects and drive to resolution.
• Provide quick response to key customer’s request on technical support.
• Provide technical training to Sales team and customers.
• 5 years+ of experience with Storage controller, Storage system.
• Knowledge and experience in SAS Firmware/Software, Fiber Channel and SAS server system
• Experience using or supporting storage products eg. SAS processor/Controller/Expander or
storage system
• Broad Network or Storage knowledge
• Demonstrated ability to learn technology quickly
• Very good English communication skills
• Team player, self-motivation
• Communication/Information Systems or EE degree, Masters preferred
12.
Test Integration Optimization-Zhuhai
Job Description
Your responsibilities will include but not be limited to: Maintain testing processes, equipment and software to test disk array products in a manufacturing environment. Driving testing cycle time reduction. Work with TDE/design community to maintain/implement appropriate test methods in production. Provide support to technical staff in determining root cause of system failures and driving appropriate corrective action through test enhancements, design changes or process modification to prevent defects in disk array components. Also provide guidance to design community (software and hardware) on Design for Manufacturability (DFM) and Design for Testability (DFT) and Built-in Self Test (BIST) as well as maintaining and promoting test strategy development consistent with technology changes. The ideal candidate will have 5 or more years of experience in the following areas: 1. Use of oscilloscopes, logic analyzers and bus dis-assemblers. 2. Software maintenance/development in Java, 'C' or C++ for PC, Unix and Intel microprocessors 3. Microsoft Office suite of PC applications - primarily Excel and Word 4. Manufacturing assembly and test methods. 5. Knowledge of disk drive technology and operation, specifically Fiber Channel devices and SAS / SATA devices 6. International travel required.
(1) BS Computer Eng, Electrical Eng, or Computer Science.
(2) 5+ years experience in engineering, manufacturing test development, or related position for storage controllers, servers, or similar systems.
(3) Experience with being able to remotely address and coordinate test releases, issues or NPI (New Product Introduction) in cooperation with outsourced design suppliers and Contract Manufacturers (CM's) preferred
(4) Experience with and knowledge of server architecture, CPUs, memories, PCI bus, I2C bus, serial I/F, Ethernet I/F, and storage IO I/Fs (e.g. SAS, iSCSI, FC).
(5) Knowledge & experience of the Linux OS and programming experience in C and C++ required and Java is preferred.
(6) Experience in maintaining/optimizing diagnostics and test functions for HW listed above.
(7) Excellent written and verbal communications skills in English and Chinese. (8) Good problem solving and process troubleshooting skills
发表于 2011-2-25 19:53:07 | 显示全部楼层
LSI 到底要招多少人啊!
发表于 2011-2-26 20:38:41 | 显示全部楼层
好像 一直在招聘呢
发表于 2011-2-28 11:13:56 | 显示全部楼层
怎么不说待遇呢
发表于 2011-2-28 16:28:42 | 显示全部楼层
好机会
GMT+8, 2025-12-22 07:20 , Processed in 0.078763 second(s), 7 queries , Gzip On, Redis On.
