查看: 4004|回复: 4
[求助] 在verilog中怎么描述ROM并赋值???
发表于 2011-2-21 21:46:06 | 显示全部楼层 |阅读模式
subtype ROM_WORD is std_logic_vector (31 downto 0);
   type ROM_TABLE is array (0 to 15) of ROM_WORD;
   constant Zero_32 :ROM_WORD := "00000000000000000000000000000000";
   constant RomWord13 :ROM_WORD := "000000000000000000000000"& CAP_PTR;
   constant RomWord15 :ROM_WORD := MAX_LAT & MIN_GNT & INT_PIN &INT_LINE;
   constant ROM: ROM_TABLE := ROM_TABLE'(
      ROM_WORD'(DEVICE_ID & VENDOR_ID),
      ROM_WORD'(Zero_32),
      ROM_WORD'(CLASS_ID & REV_ID),
      ROM_WORD'(Zero_32),
      ROM_WORD'(BAR0_MAP),
      ROM_WORD'(BAR1_MAP),
      ROM_WORD'(BAR2_MAP),
      ROM_WORD'(BAR3_MAP),
      ROM_WORD'(BAR4_MAP),
      ROM_WORD'(BAR5_MAP),
      ROM_WORD'(Zero_32),
      ROM_WORD'(SUBDEVICE_ID & SUBVENDOR_ID,
      ROM_WORD'(EBAR_MAP),
      ROM_WORD'(RomWord13),
      ROM_WORD'(Zero_32),
      ROM_WORD'(MAX_LAT & MIN_GNT & INT_PIN &INT_LINE));
以上是VHDL写的,32位宽,深度16的ROM,并赋值。verilog中怎么写?? 多谢!!!
发表于 2011-2-22 10:29:53 | 显示全部楼层
看看QuartusII中的EDIT--INSERT TEMPLATE. 里面就有。
发表于 2011-2-22 14:43:41 | 显示全部楼层
可以用RAM代替
然后在simulation开始时用$readmemh("init_data.dat", mem);初始化声明的memory
发表于 2011-2-22 15:45:24 | 显示全部楼层
写个always块,类似如下
always @(*)begin
         case(addr)begin
                 00: data<=xxx;
                 01: data<=xxx;
                 10: data<=xxx;
                 11: data<=xxx;
         endcase
end
发表于 2012-4-28 10:49:41 | 显示全部楼层
回复 3# stanelor
   你这个是FPGA吧,不是ASIC
GMT+8, 2025-12-27 12:51 , Processed in 0.034749 second(s), 3 queries , Gzip On, Redis On.
