查看: 24412|回复: 1
[原创] CCS报错 error: expected an expression如何解决?
发表于 2011-2-20 15:13:40 | 显示全部楼层 |阅读模式
我按照参考书上的示例程序编写自己的初始化程序:void init_board(void)
*(volatile unsigned int *)CLKMD=0x0000;
while(*(volatile unsigned int *)CLKMD & 0x0001){};
*(volatile unsigned int *)CLKMD=CLKMD_VAL;
*(volatile unsigned int *)PMST=PMST_VAL;
*(volatile unsigned int *)SWWSR=SWWSR_VAL;
*(volatile unsigned int *)SWCR=SWCR_VAL;
*(volatile unsigned int *)BSCR=BSCR_VAL;
*(volatile unsigned int *)ST1=ST1_VAL;
//设置CPU寄存器
*(volatile unsigned int *)SPSA0=SPCR10;
//以下初始化MCBSP0
*(volatile unsigned int *)SPSD0=SPCR10_VAL;
*(volatile unsigned int *)SPSA0=SPCR20;
*(volatile unsigned int *)SPSD0=SPCR20_VAL;
*(volatile unsigned int *)SPSA0=RCR10;
*(volatile unsigned int *)SPSD0=RCR10_VAL;
*(volatile unsigned int *)SPSA0=RCR20;
*(volatile unsigned int *)SPSD0=RCR20_VAL;
*(volatile unsigned int *)SPSA0=XCR10;
*(volatile unsigned int *)SPSD0=XCR10_VAL;
*(volatile unsigned int *)SPSA0=XCR20;
*(volatile unsigned int *)SPSD0=XCR20_VAL;
*(volatile unsigned int *)SPSA0=SRGR10;
*(volatile unsigned int *)SPSD0=SRGR10_VAL;
*(volatile unsigned int *)SPSA0=SRGR20;
*(volatile unsigned int *)SPSD0=SRGR20_VAL;
*(volatile unsigned int *)SPSA0=PCR0;
*(volatile unsigned int *)SPSD0=PCR0_VAL;
结果每一行都报错:
"initialize.h", line 5: error: expected an expression
"initialize.h", line 6: error: expected a ")"
"initialize.h", line 7: error: expected an expression
"initialize.h", line 8: error: expected an expression
"initialize.h", line 9: error: expected an expression
"initialize.h", line 10: error: expected an expression
"initialize.h", line 11: error: expected an expression
"initialize.h", line 12: error: expected an expression
"initialize.h", line 13: error: expected an expression
"initialize.h", line 14: error: expected an expression
"initialize.h", line 15: error: expected an expression
"initialize.h", line 16: error: expected an expression
"initialize.h", line 17: error: expected an expression
"initialize.h", line 18: error: expected an expression
"initialize.h", line 19: error: expected an expression
"initialize.h", line 20: error: expected an expression
"initialize.h", line 21: error: expected an expression
"initialize.h", line 22: error: expected an expression
"initialize.h", line 23: error: expected an expression
"initialize.h", line 24: error: expected an expression
"initialize.h", line 25: error: expected an expression
"initialize.h", line 26: error: expected an expression
"initialize.h", line 27: error: expected an expression
"initialize.h", line 28: error: expected an expression
"initialize.h", line 29: error: expected an expression
"initialize.h", line 30: error: expected an expression
26 errors detected in the compilation of "control.c".
寄存器名是在另一个头文件中定义的,如:
#define ST1 0x0007;//Status register 0
#define ST0 0x0006;//Status register 1
#define PMST 0x001d;//Processor mode status (PMST) register
#define SWWSR 0x0028;//Software Wait-State Register
#define SWCR 0x002b;//Software Wait-State Control Register
#define BSCR 0x0029;//Bank-Switching Control Register
#define CLKMD 0x0058;//Clock Mode Register (CLKMD)
请高手解答 我用的是CCS 2.21
 楼主| 发表于 2011-2-21 10:31:54 | 显示全部楼层
回复 1# congfeiyu
自己回答:原来是由于我在宏定义后面加了分号,去掉后就正常了
GMT+8, 2025-9-19 06:40 , Processed in 1.344903 second(s), 5 queries , Gzip On, Redis On.
