查看: 3805|回复: 12
[资料] Circuits and Systems I: Regular Papers 2011 Feb
发表于 2011-2-16 19:04:41 | 显示全部楼层 |阅读模式
REGULAR PAPERS
    Analog and Mixed Mode Circuits and Systems
1、Alias Rejection of Continuous-Time Modulators With Switched-Capacitor Feedback DACs
     S. Pavan 233
2、A Polar-Transmitter Architecture Using Multiphase Pulsewidth Modulation
     J.-H. Chen, H.-S. Yang, H.-C. Lin, and Y.-J. E. Chen 244
3、Clock-Jitter-Tolerant Wideband Receivers: An Optimized Multichannel Filter-Bank Approach
     S. Hoyos, S. Pentakota, Z. Yu, E. Sobhy Abdel Ghany, X. Chen, R. Saad, S. Palermo, and J. Silva-Martinez 253
4、A Discrete-Time Model for the Design of Type-II PLLsWith Passive Sampled Loop Filters
     K. J. Wang and I. Galton 264
5、Noise and Nonlinearity Modeling of Active Mixers for Fast and Accurate Estimation
     W. Cheng, A. J. Annema, J. A. Croon, and B. Nauta 276
6、Low-Power Discrete Fourier Transform for OFDM: A Programmable Analog Approach
     S. Suh, A. Basu, C. Schlottmann, P. E. Hasler, and J. R. Barry 290
7、A General Analytical Tool for the Design of Vibration Energy Harvesters (VEHs) Based on the Mechanical Impedance
Concept
     D. Galayko and P. Basset 299
    Nonlinear Circuits and Systems
8、Theory of Injection-Locked Oscillator Phase Noise
     T. Djurhuus and V. Krozer 312
9、Exponential Stability, Semistability, and Boundedness of a Multi-ANF System
     Z. Chu, M. Ding, S. Du, and X. Feng 326
10、A Graphical Approach to Prove Contraction of Nonlinear Circuits and Systems
     G. Russo, M. di Bernardo, and J.-J. E. Slotine 336
11、Robust Synchronization Design of Nonlinear Coupled Network via Fuzzy Interpolation Method
     B.-S. Chen, C.-H. Chiang, and S. K. Nguang 349
12、Evaluation of Gunshot Detection Algorithms
     A. Chacón-Rodríguez, P. Julián, L. Castro, P. Alvarado, and N. Hernández 363
    Computer Aided Design and Electronic Design Automation
13、Solving Large-Scale Hybrid Circuit-Antenna Problems
     J. Lavaei, A. Babakhani, A. Hajimiri, and J. C. Doyle 374
    Control Theory and Systems
14、Stabilization of a Class of Linear SystemsWith Input Delay and the Zero Distribution of Their Characteristic Equations
     B. Zhou, Z. Lin, and G. Duan 388
    Circuits and Systems for Communications
15、Efficient Partial-Parallel Decoder Architecture for Quasi-Cyclic Nonbinary LDPC Codes
     X. Zhang and F. Cai 402
16、Processing-Task Arrangement for a Low-Complexity Full-Mode WiMAX LDPC Codec
     Y.-L. Wang, Y.-L. Ueng, C.-L. Peng, and C.-J. Yang 415
17、On the Use of Soft-Decision Error-Correction Codes in NAND Flash Memory
     G. Dong, N. Xie, and T. Zhang 429
CAS-I 2011 02feb.rar
13.74 MB, 下载次数: 155 , 下载积分: 资产 -5 信元, 下载支出 5 信元
发表于 2011-2-16 19:56:10 | 显示全部楼层
thanks a lot
发表于 2011-2-17 07:18:02 | 显示全部楼层
下来看看,谢谢。
发表于 2011-2-17 11:23:42 | 显示全部楼层
IEEE 有得下呵
发表于 2011-2-17 13:06:52 | 显示全部楼层
IEEE 有得下呵
发表于 2011-2-17 22:45:41 | 显示全部楼层
非常好的文章,谢谢!
发表于 2011-2-20 15:07:02 | 显示全部楼层
thanks
发表于 2011-2-20 17:12:13 | 显示全部楼层
关注关注。。
发表于 2011-3-2 22:16:02 | 显示全部楼层
paper真是工程師的精神糧食
发表于 2011-3-3 00:44:23 | 显示全部楼层
ddddddddddddddddddddddd
GMT+8, 2025-12-26 17:41 , Processed in 0.034938 second(s), 8 queries , Gzip On, Redis On.
