楼主: beginner001
[资料] IC Compiler 2009.06 workshop(PDF)+LAB数据文件-应该是目前最新的ICC的WORKSHOP
发表于 2013-8-26 13:12:05 | 显示全部楼层
Like GDSII, OASIS is an industry-standard data exchange format for integrated circuit layout
information. OASIS, which stands for Open Artwork System Interchange Standard, is
designed as an improved replacement for GDSII that allows integer bit widths to exceed the
16-bit and 32-bit limits imposed by the GDSII standard. It also has several efficiency
improvements to support larger designs.
You can read an OASIS file into the Milkyway Environment by using either the GUI or the
read_oasis Tcl command. To use the GUI, set the command entry mode to Scheme and
enter the Scheme command read_oasis. This opens the Oasis In Data File dialog box,
which shows the options for reading OASIS data and converting the data to the Milkyway
发表于 2013-8-26 22:03:30 | 显示全部楼层
果然好东西~~~
发表于 2013-8-31 05:02:11 | 显示全部楼层
多谢分享!!!!!!
发表于 2013-9-9 15:19:06 | 显示全部楼层
第三个文件是骗人的吧,明明是lab,却说是workshop
发表于 2013-9-13 01:40:36 | 显示全部楼层
Post CTS: Uncertainty will be decreased in SDC. Clock skew (including the OCV) target will be
given in ctstch.
eg:A 1 ns clock with a 100 ps clock uncertainty means that the next clock tick will arrive in 1 ns
plus or minus 50 ps.
Setup uncertainty should include all of them (capture clock and launch clock are different) but
we can ignore PLL jitter in hold uncertainty (capture clock and launch clock are same), and OCV
uncertainty for hold can be less than setup.
发表于 2013-10-9 12:06:59 | 显示全部楼层
好东西必须要顶~~多谢LZ!!
发表于 2013-10-12 14:00:07 | 显示全部楼层
正在找着个东西了  刚好需要
发表于 2013-10-20 21:40:06 | 显示全部楼层
谢谢楼主!
发表于 2013-10-30 16:25:16 | 显示全部楼层
谢谢分享!
发表于 2013-11-5 20:30:06 | 显示全部楼层
感谢费你想啊
GMT+8, 2025-12-17 02:09 , Processed in 0.020422 second(s), 5 queries , Gzip On, Redis On.
