查看: 2397|回复: 1
Tiger Woods Grip with Ping K15 Irons
发表于 2011-1-21 10:18:11 | 显示全部楼层 |阅读模式
Once you think you have the two grips feeling similar then stand up and make a stance. After you make a stance lift your grip up in front of your face again so you can see and feel the proper grip.
Go ahead a make a full golf swing now. Once you make a swing hold your finish. If you have trouble holding your finish position with ping k15 irons you have a problem somewhere in your swing motion. Once holding the finish swivel your head over to the mirror and see if your back is nice and straight and that you’re balanced on your front foot with ping k15 irons.
ishiner
发表于 2011-1-24 14:02:50 | 显示全部楼层
that's a good startpoint
GMT+8, 2025-12-22 09:41 , Processed in 0.013913 second(s), 4 queries , Gzip On, Redis On.
