查看: 23862|回复: 25
[讨论] 請問有人有用 integrand EMX 軟体嗎?
发表于 2011-1-19 17:08:10 | 显示全部楼层 |阅读模式
发表于 2011-5-11 17:43:05 | 显示全部楼层
好问题!我也想问这个。楼主,你找到答案了吗?
发表于 2011-8-15 18:22:37 | 显示全部楼层
听说 EMX 速度比较快, 准确度也还可以.
有人有用过吗? 那里找的到?
发表于 2011-11-16 16:42:36 | 显示全部楼层
I am using it,vrey fast and accuracy
发表于 2012-7-12 02:40:17 | 显示全部楼层
graet tha
发表于 2012-7-14 00:52:52 | 显示全部楼层
To evaluate the high accuracy of EMX is very tough, if the user know the true EM principle.
The frequency below 3 GHz is good to operated in EMX.
However, the bands from 5-40 GHz, the quality factor is a great problem.
The frequency operated above 60 GHz upto 200 GHz, maybe this software has some merits.
Meanwhile, it is not an easy work to set the ABS or other condition to enhance the total accuracy.
By the way, EMX is really a foollike-software. Once you use it, you will never find the real mechanism to solve the problem.
发表于 2012-7-15 00:53:08 | 显示全部楼层
但你用hfss/momentum等别的软件一样不知道他是怎么算的啊。。。我觉得都差不多。。。
发表于 2013-4-18 22:29:29 | 显示全部楼层
哪有有下载啊?
发表于 2013-10-23 11:11:44 | 显示全部楼层
emx速度很快,在微波的精度其实也蛮好,主要是在多port下,速度和精度平衡的很好。从一些国外高校(比如TU Delft)做的毫米波电路来看,emx也能适用,我自己做的passive和active下的感觉是仿真和测试非常准,频率也是远远超过3G的。emx使用上确实很方便,有点傻瓜式的,在具体的设置上建议多看看它的manual。
发表于 2014-7-9 17:56:24 | 显示全部楼层
有人又manual么,上传下看看怎么样呢。
GMT+8, 2025-12-27 11:06 , Processed in 0.019557 second(s), 4 queries , Gzip On, Redis On.
