查看: 8825|回复: 26
[资料] 一些analog方面的papaer
发表于 2011-1-17 10:36:03 | 显示全部楼层 |阅读模式
目录:
1  :  F. Maloberti, V. Svelto: "On the Stability of Transferred Electron Amplifiers"; Alta Frequenza, Vol. XXXIX, No. 11, 1970, pp. 1010-1011. (pdf)
2  :  F. Maloberti, V. Svelto: "Noise Spectrum and Noise Figure of a Device with Bulk Negative Differential Mobility"; Alta Frequenza, Vol. XL, 1971, pp. 667-673. (pdf)
3  :  P.G. Erratico, F. Maloberti, V. Svelto: "JGFET Thermal Noise in Hot Electrons Regime"; Alta Frequenza, Vol. XLI, 1972, pp. 683-689. (pdf)
4  :  F. Maloberti, F. Montecchi, V. Svelto: "Flicker Noise in Thick Film Resistors"; Alta Frequenza, Vol. XLIV, No. 11, 1975, pp. 681-683. (pdf)
5  :  E. Gatti, F. Maloberti, V. Svelto: "Static Negative Resistance Phenomena in GaAs Devices"; Alta Frequenza, Vol. XLV, 1976, pp. 252-256. (pdf)
6  :  F. Maloberti, F. Montecchi, V. Svelto: "An Exact Analysis of a Switched-Capacitor Circuit"; Alta Frequenza, Vol. XLIX, No. 3, 1980, pp. 213-217. (pdf)
7  :  F. Maloberti, F. Montecchi, V. Svelto: "Noise and Gain in a SC Integrator with Real Operational Amplifier"; Alta Frequenza, Vol. L, No.1, 1981, pp. 4-11. (pdf)
8  :  F. Maloberti, F. Montecchi: "A New Type of Successive Approximation A/D Converter with Switched Capacitors"; Alta Frequenza, Vol. LI, No. 2, 1982, pp. 93-95. (pdf)
9  :  F. Maloberti, F. Montecchi: "Low-Frequency Noise Reduction in SC Ladder Filters"; Electronics Letters, Vol. 18, No. 15, 22nd July 1982, pp. 674-676. (pdf)
10 :  F. Maloberti, F. Montecchi: "Comment on: Parasitic Insensitive toggle-Switched Capacitor and Its Applications to Switched-Capacitor Networks"; Electronics Letters, Vol. 18, No. 24, 25th Nov. 1982, p. 1061. (pdf)
11 :  F. Maloberti: "Switched-Capacitor Building Blocks for Analogue Signal Processing"; Electronics Letters, Vol. 19, No. 7, 1983, pp. 263-265. (pdf)
12 :  F. Maloberti, G. Palmisano: "Four Quadrants Switched Capacitor Analog Multiplier"; Alta Frequenza, Vol. LIII, n. 6, 1984, pp. 328-331. (pdf)
13 :  C. Canosi, A. Colamonico, M. Donati, F. Maloberti: "Switched Capacitor Filters for a 1200 baud FFSK Modem"; Annales des Telecommunications, Vol. 40, n. 5-6, 1985, pp. 235-242. (pdf)
14 :  F. Maloberti, F. Montecchi: "Low-Frequency Noise Reduction in Time-Shared Switched-Capacitor Ladder Filters"; IEE Proc. - G, Electronic Circuits and Systems, Vol. 132, April 1985, pp. 39-45. (pdf)
15 :  F. Maloberti: "An Efficient Method for the Numerical Analysis of Transients in Linear-Dynamic Circuits"; IEEE Transaction on Circuits and Systems, Vol. CAS-32, August 1985, pp. 848-851. (pdf)
16 :  F. Maloberti, F. Montecchi, G. Torelli, E. Halasz: "Bilinear design of Fully differential Switched-Capacitors Ladder Filters"; IEE Proc. Electronic circuits and systems, Part G, Vol. 132, 1985, pp. 266-272. (pdf)
17 :  K. Haug, F. Maloberti, G.C. Temes: "Switched-Capacitor Integrators with low finite-gain Sensitivity"; Electronics Letters, Vol. 21, November 21, 1985, pp. 1156-1157. (pdf)
18 :  V. Liberali, F. Maloberti, G. Palmisano: "High Frequency Performance Limitations of Low Pass Anti Aliasing Filters"; Alta Frequenza, Vol. LVI, 1987, pp. 305-309. (pdf)
19 :  G. Lutz, F. Maloberti, P.F. Manfredi, V. Re, V. Speziali, V. Buttler, H. Vogt: "On the design of a JFET-CMOS front-end for low noise data acquisition from microstrip detectors"; Nuclear Inst. and Methods in Physics Research, 1988, pp. 391-398. (pdf)
20 :  G. Chiappano, A. Colamonico, M. Donati, F. Maloberti, F. Montecchi, G. Palmisano: "A Tunable Switched Capacitor Programmable N-path Tone Receiver and Generator"; IEEE J. of Solid State Circuits, Vol. 23, Dec. 1988, pp. 1418-1425. (pdf)
21 :  W. Buttler, G. Lutz, V. Liberali, F. Maloberti, P.F. Manfredi, V. Re, V. Speziali: "Evolution in the criteria that underlie the design of a monolithic preamplifier system for microstrip detectors"; Nuclear Instruments and Methods in Physsics Research, North-Holland, Vol. 288, 1990, pp. 140-149. (pdf)
22 :  A. Cremonesi, F. Maloberti, G. Polito: "A 100-MHz CMOS DAC for video-graphic systems"; IEEE J. of Solid State Circuits, Vol. 24, June 1989, pp. 635-639. (pdf)
23 :  W. Buttler, V. Liberali, G. Lutz, F. Maloberti, P.F. Manfredi, V. Re, V. Speziali: "JFET-CMOS Microstrip Front-end"; Nuclear Instrum. and Meth in Phys. Res. A, Vol. 279, 1989, pp. 204-211. (pdf)
24 :  J. Vital, J.E. Franca, F. Maloberti: "Integrated Mixed-Mode Digital-Analog Filter Converters"; IEEE J. of Solid State Circuits, Vol. 25, June 1990, pp. 660-668. (pdf)
25 :  U. Gatti, V. Liberali, F. Maloberti, P. O'Leary: "Automatic Switching of Substrate bias or Well bias in CMOS-ICs"; Electronics Letters, 1990, pp.1381-1382. (pdf)
26 :  P. O'Leary, F. Maloberti: "Bit stream adder for oversampling coded data"; Electronics Letters, Vol. 26, No. 20, 1990, pp. 1708-1709. (pdf)
27 :  G. Chiappano, A. Colamonico, M. Donati, F. Maloberti, F. Montecchi, G. Palmisano: "Custom Integrated Circuits for Audio Processing and Signalling in Vehicular Units"; European Transaction on Telecommunications and Related Technologies, Vol. 1, n. 6, November-December, 1990, pp. 603-610. (pdf)
28 :  P. O'Leary, H. Horvat, F. Maloberti: "Direct Digital Synthesis Applied to Modulators for Data Communication"; Journal of Semicustom ICs, Vol. 8, No. 3, England, 1991, pp. 32-41. (pdf)
29 :  P. O'Leary, M. Pauritsch, F. Maloberti, G. Raschetti: "An Oversampling-based DTMF Generator"; IEEE Trans. on Communications, Vol. 39, No. 8, August 1991, pp. 1189-1191. (pdf)
30 :  P. O'Leary, F. Maloberti: "A direct-digital synthesizer with improved spectral performance"; IEEE Trans. on Communications, Vol. 39, No. 7, July 1991, pp. 1046-1048. (pdf)
31 :  P. O'Leary, F. Maloberti: "Oversampling-Based Balanced Modulator"; Electronics Letters, Vol. 27, No. 1, January 3, 1991, pp. 66-68. (pdf)
32 :  P. O'Leary, F. Maloberti: "Oversampling Applied to Single Tone Detection"; Electronics Letters, Vol. 27, No. 1, January 3, 1991, pp. 76-77. (pdf)
33 :  U. Gatti, F. Maloberti, G. Torelli: "Design and Verification of a CMOS Transconductance Cell with Extended Linearity"; European Transaction on Telecommunications and Related Technologies, Vol. 2, No. 4, 1991, pp. 441-446. (pdf)
34 :  U. Gatti, F. Maloberti, G. Palmisano: "An Accurate CMOS Sample-and-Hold Circuit"; IEEE J. of Solid State Circuits, Vol. 27, Jan. 1992, pp. 120-122. (pdf)
35 :  V.F. Dias, G. Palmisano, P. O'Leary, F. Maloberti: "Fundamental Limitations of Switched-Capacitor Sigma-Delta Modulators"; IEE Proceedings Part G: Cicuits, Devices and Systems, Vol. 139, Feb. 1992, pp. 27-32. (pdf)
36 :  O. Alminde, U. Gatti, V. Liberali, F. Maloberti, P. O'Leary: "An Integrated CMOS Telephone Line Adapter"; Analog Integrated Circuits and Signal Processing, 1992, pp. 71-78. (pdf)
37 :  B. Baggini, F. Maloberti, G. Palmisano: "Accurate Low-Power CMOS Autozeroed Comparator"; Electronics Letters, Vol. 28, May 1992, pp. 916-918. (pdf)
38 :  B. Baggini, L. Coppero, G. Gazzoli, L. Sforzini, F. Maloberti, G. Palmisano: "An Integrated Circuit for GSM Mobile Communications"; Analog Integrated Circuits and Signal Processing, Vol. 2, 1992, pp. 197-206. (pdf)
39 :  F. Maloberti, G. Marchesi, G. Torelli: "CMOS Data Output Buffer for Integrated Memories"; Electronics Letters, Oct. 1992, Vol. 28, No. 21, pp. 1946-1947. (pdf)
40 :  V.F. Dias, G. Palmisano, F. Maloberti: "Noise in Mixed Continuous-time Switched-Capacitor Sigma-Delta Modulators"; IEE Proceedings Part G: Cicuits, Devices and Systems, Vol. 139, Dec. 1992, pp. 680-684. (pdf)
41 :  V.F. Dias, V. Liberali, F. Maloberti: "Design Tools for Oversampled Data Converters: Needs and Solutions"; Microelectronics Journal, n. 23, 1992, pp. 641-650. (pdf)
42 :  F. Maloberti, G. Torelli, C. Panini, M. Troiani, R. Roncella, P. Terreni, C. Toncelli, R. Saletti: "ASIC-based acoustic echo-canceller board for VME bus"; European Transactions on Telecommunications and Related Technologies, vol. 3, no. 2, Mar.-Apr. 1992, pp. 125-136. (pdf)
43 :  V. Liberali, V.F. Dias, M. Ciapponi, F. Maloberti: "TOSCA: A simulator for Switched-Capacitor Noise-Shaping A/D Converters"; IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, Vol. 12, n. 9, September 1993, pp. 1376-1386. (pdf)
44 :  G. Caiulo, F. Maloberti, G. Palmisano, S. Portaluri: "Video CMOS Power Buffer with Extended Linearity"; IEE Journal of Solid-State Circuits, Vol. 28, n. 7, July 1993, pp. 845-848. (pdf)
45 :  A. Dell'Acqua, M. Hansen, B. Lofstedt, J.P. Vanuxem, C. Svensson, J. Yuan, H. Hentzell, C. Alippi, L. Breveglieri, L. Dadda, V. Piuri, F. Salice, M. Sami, R. Stefanelli, P. Cattaneo, G. Fumagalli, V.G. Goggi, S. Brigati, U. Gatti, F. Maloberti, G. Torelli, P. Carlson, C. Fuglesang, A. Kerek, G. Appelquist, S. Berglund, C. Bohm, N. Yamdagni, C.R. Sundblad: "A Digital Front-end and Readout Microsystem for Calorimetry at LHC - The FERMI project"; IEEE Transactions on Nuclear Science, Vol. 40, n. 4, August 1993, pp. 516-531. (pdf)
46 :  R.P. Martins, J.E. Franca, F. Maloberti: "An Optimum CMOS Switched-Capacitor Antialiasing Decimating Filter"; IEEE Journal of Solid-State Circuits, Vol. 28, n. 9 September 1993, pp. 962-970. (pdf)
47 :  S. Brigati, C. Alippi, G. Appelquist, S. Berglund, C. Bohm, L. Breveglieri, P. Carlson, P. Cattaneo, L. Dadda, I. David, A.L. Del Buono, A. Dell'Acqua, M. Engstrom, G. Fumagalli, U. Gatti, J.F. Genat, G. Goggi, M. Hansen, H. Hentzell, I. Hoglund, S. Inkinen, A. Kerek, H. Lebbolo, O. LeDortz, B. Lofstedt, F. Maloberti, P. Nayman, S.T. Persson, V. Piuri, F. Salice, M. Sami, A. Savoy Navarro, R. Stefanelli, R. Sundblad, C. Svensson, G. Torelli, J.P. Vanuxem, N. Yamdagni, J. Yuan: "FERMI - A New Generation of Electronic Modules for Large Data Acquisition Arrays Required by High Energy Physics"; IEEE Transactions on Components, Packaging, and Manufacturing Technology Part B: Advanced Packaging, Vol. 17, n. 3, August 1994, pp. 302-309. (pdf)
48 :  C. Alippi, G. Appelquist, S. Berglund, C. Bohm, L. Breveglieri, S. Brigati, P. Carlson, P. Cattaneo, L. Dadda, J. David, L. Del Buono, A. Dell'Acqua, M. Engstrom, G. Fumagalli, U. Gatti, J.F. Genat, G. Goggi, M. Hansen, H. Hentzell, I. Hoglund, S. Inkinen, A. Kerek, H. Lebbolo, O. LeDortz, B. Lofstedt, F. Maloberti, P. Nayman, S.-T. Persson, V. Piuri, F. Salice, M. Sami, A. Savoy-Navarro, R. Stefanelli, R. Sundblad, C. Svensson, G. Torelli, J.P. Vanuxem, N. Yamdagni, J. Yuan, R. Zitoun: "A Digital Front-End and Readout Microsystem for Calorimetry at LHC"; Nuclear Instruments & methods in Physics Research, Section A, N.H. Elsevier, Vol. 344, 1994, pp. 180-184. (pdf)
49 :  S. Brigati, F. Maloberti, G. Torelli, "Speed limitations in CMOS data converters with switch selection networks"; Microelectronics Journal, Elsevier, Vol. 25, no. 4, June 1994, pp. 279-285. (pdf)
50 :  L. Civardi, U. Gatti, F. Maloberti, G. Torelli: "An Integrated CMOS Interface for Lambda Sensor"; IEEE Transactions on Vehicular Technology, Vol. 43, No. 1, February 1994, pp. 40-46. (pdf)
51 :  V.F. Dias, G. Palmisano, F. Maloberti: "Harmonic Distortion in SC Sigma-Delta Modulators"; IEEE Transactions on circuits and System-I: Fundamental Theory and Applications, Vol. 41, n. 4, April 1994, pp. 326-329. (pdf)
52 :  P. Malcovati, C. Azeredo Leme, P. O'Leary, F. Maloberti, H. Baltes: "Smart Sensor Interface with A/D Conversion and Programmable Calibration"; IEEE Journal of Solid-State Circuits, Vol. 29, n. 8, August 1994, pp. 963-966. (pdf)
53 :  E. Chioffi, F. Maloberti, G. Marchesi, G. Torelli: "High-Speed, Low-Switching Noise CMOS Memory Data Output Buffer"; IEEE Journal of Solid-State Circuits, Vol. 29, No. 11, November 1994, pp. 1359-1365. (pdf)
54 :  G. Lazzari, F. Maloberti, G. Oliveri, G. Torelli: "Sinewave Modulation for Data Communication by Direct Digital Synthesis and Sigma Delta Techniques"; European Transactions on Telecommunications and Related Technologies, Vol. 5, n. 6, November-December 1994, pp. 689-695. (pdf)
55 :  U. Gatti, F. Maloberti, G. Palmisano, G. Torelli: "CMOS Triode-Transistor Transconductor for High-Frequency Continuous-Time Filters"; IEE Proceedings - Circuits, Devices and Systems, Vol. 141, No. 6, December 1994, pp. 462-468. (pdf)
56 :  J.F. Duque-Carrillo, G. Torelli, R. Perez-Aloe, J.M. Valverde, F. Maloberti: "Fully Differential Basic Building Blocks Based on Fully Differential Difference Amplifiers with Unity-Gain Difference Feedback"; IEEE Transactions on Circuits and Systems -I: Fundamental theory and applications, Vol. 42, No. 3, March 1995, pp. 190-192. (pdf)
57 :  P. Malcovati, C.A. Leme, R. Lenggenhager, F. Maloberti, H. Baltes: "Low-Noise Multirate SC Read-Out Circuitry for Thermoelectric Integrated Infrared Sensors"; IEEE Transactions on Instrumentation and Measurement, Vol. 44, No. 3, June, 1995, pp. 795-798. (pdf)
58 :  H. Alexanian, G. Appelquist, P. Bailly, R. Benetta, S. Berghlund, J. Bezamat, F. Blouzon, C. Bohm, L. Breveglieri, S. Brigati, P.W. Cattaneo, L. Dadda, J. David, M. Engstrom, J.F. Genat, M. Givoletti, V.G. Goggi, S. Gong, G.M. Grieco, M. Hansen, H. Hentzell, T. Holmberg, I. Hoglund, S.J. Inkinen, A. Kerek, C. Landi, O. LeDortz, M. Lippi, B. Lofstedt, B. Lund-Jensen, F. Maloberti, S. Mutz, P. Nayman, V. Piuri, G. Polesello, M. Sami, A. Savoy-Navarro, P. Schwemling, R. Stefanelli, R. Sundblad, C. Svensson, G. Torelli, J.P. Vanuxem, N. Yamdagni, J. Yamdagni, J. Yuan, A. Odmark: "FERMI: a digital Front End and Readout Microsystem for high resolution calorimetry"; Nuclear Instruments & Methods in Phisics Research, Section A, 1995, pp. 306-317. (pdf)
59 :  H. Alexanian, G. Appelquist, P. Bailly, R. Benetta, S. Berglund, J. Bezamat, F. Blouzon, C. Bohm, L. Breveglieri, S. Brigati, P.W. Cattaneo, L. Dadda, J. David, M. Engstrom, J.F. Genat, M. Givoletti, V.G. Goggi, S. Gong, G.M. Grieco, M. Hansen, H. Hentzell, T. Holmberg, I. Hoglund, S.J. Inkinen, A. Kerek, C. Landi, O. LeDortz, M. Lippi, B. Lofstedt, B. Lund-Jensen, S. Mutz, P. Nayman, V. Piuri, G. Polesello, M. Sami, A. Savoy-Navarro, P. Schwemling, R. Stefanelli, R. Sundblad, C. Svensson, G. Torelli, J.P. Vanuxem, N. Yamadagni, J. Yuan, A. Odmark, F. Maloberti: "Optimized Digital Feature Extractionin the FERMI Microsystem"; Nuclear Instruments & Methods in Physics Research, Section A, 1995, pp. 318-328. (pdf)
60 :  A. Simoni, G. Torelli, F. Maloberti, A. Sartori, S.E. Plevridis, A.N. Birbas: "A Single-Chip Optical Sensor with Analog Memory for Motion Detection"; IEEE Journal of Solid State Circuits, Vol. 30, No. 7, July 1995, pp. 800-806. (pdf)
61 :  A. Sartori, F. Maloberti, A. Simoni and G. Torelli: "A 2D Photosensor Array with Integrated Charge Amplifier"; Sensors and Actuators A - Physical, Vol. 46-47, No. 1-3, 1995, pp. 247-250. (pdf)
62 :  F. Maloberti, F. Francesconi, P. Malcovati, O.J.A.P. Nys: "Design Considerations on Low-Voltage Low-Power Data Converters"; IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, Vol. 42, No. 11, November 1995, pp. 853-863. (pdf)
63 :  P. Malcovati, R. Castagnetti, F. Maloberti, H. Baltes: "A magnetic sensor with current-controlled sensitivity and resolution"; Sensors and Actuators A: Physical, Vol. 46, No. 1-3, 1995, pp. 284-288. (pdf)
64 :  J.F. Duque-Carrillo, P. Malcovati, F. Maloberti, R. Perez-Aloe, A.H. Reyes, E. Sanchez-Sinencio, G. Torelli, J.M. Valverde: "VERDI: An Acoustically Programmable and Adjustable CMOS Mixed-Mode Signal Processor for Hearing Aid Applications"; IEEE Journal of Solid State Circuits, Vol. 31, No. 5, May 1996, pp. 634-645. (pdf)
65 :  V. Colonna, F. Maloberti, G. Torelli: "Clock feedthrough compensation with phase slope control in SC circuits"; Electronics Letters, Vol. 32, No. 10, 9 May, 1996, pp. 864-865. (pdf)
66 :  G. Torelli, E. Chioffi, F. Maloberti: "A CMOS micropower input amplifier for hearing aids"; Journal Microelectronics, Elsevier, Vol. 27, No. 6, ISSN 0026-2692, September 1996, pp. 477-483. (pdf)
67 :  V. Liberali, F. Maloberti, A. Regini: "Electro-optical device models for electrical simulators"; Analog Integrated Circuits and Signal Processing, Vol. 10, No. 1/2, June-July 1996, pp. 119-130. Reprinted in: B. Antao (Ed.): "Modeling and Simulation of Mixed Analog-Digital Systems"; Kluwer Academic Publishers, 1996. (pdf)
68 :  A. Haberli, M. Schneider, P. Malcovati, R. Castagnetti, F. Maloberti, H. Baltes: "Two-Dimensional Magnetic Microsensor with On-Chip Signal Processing for Contactless Angle Measurement"; IEEE Journal of Solid State Circuits, Vol. 31, December 1996, pp. 1902-1907. (pdf)
69 :  G.C. Cardinali, L. Dori, M. Fiorini, I. Sayago, G. Faglia, C. Perego, G. Sberveglieri, V. Liberali, F. Maloberti, D. Tonietto: "A Smart Sensor System for Carbon Monoxide Detection"; Analog Integrated Circuits and Signal Processing, Vol. 14, No. 3, 1996, pp. 275-294. (pdf)
70 :  R. Perez-Aloe, J.F. Duque-Carrillo, E. Sanchez-Sinencio, J.M. Valverde, G. Torelli, A.H. Reyes, F. Maloberti: "Programmable Time-Multiplexed Switched-Capacitor Variable Equalizer for Arbitrary Frequency Response Realizations"; IEEE Journal of Solid State Circuits, Vol. 32, February 1997, pp. 274-278. (pdf)
71 :  V. Liberali, S. Brigati, F. Francesconi, F. Maloberti: "Progress in High-Speed and High-Resolution CMOS Data Converters"; Microelectronics and Reliability, Vol. 37, No. 9, 1997, pp.1411-1420. (pdf)
72 :  C.J. Debono, F. Maloberti, J. Micallef: "Low-voltage CMOS four-quadrant analogue multiplier for RF applications"; Electronics Letters, Vol. 34, No 24, November 1998, pp. 2285-2286. (pdf)
73 :  F. Maloberti, P. Malcovati: "Microsystems and Smart Sensor Interfaces: A Review"; Analog Integrated Circuits and Signal Processing, Vol. 15, No. 1, January 1998, pp. 9-26. (pdf)
74 :  A. Simoni, G. Torelli, F. Maloberti, A. Sartori, M. Gottardi, L. Gonzo: "256×256-pixel CMOS digital camera for computer vision with 32 algorithmic ADCs on board"; IEE Proceedings - Circuits, Devices and Systems, Vol. 146, No. 4, August 1999, pp. 184-190. (pdf)
75 :  S. Brigati, F. Francesconi, G. Grassi, D. Lissoni, A. Nobile, P. Malcovati, F. Maloberti, M. Poletti: "An 0.8 μm CMOS Mixed Analog-Digital Integrated Audiometric System"; IEEE Journal of Solid-State Circuits, Vol. 34, August 1999, pp. 1160-1166. (pdf)
76 :  P. Malcovati, F. Maloberti: "Integrated Microsystem for 3D Magnetic Field Measurements"; IEEE Aerospace and Electronic Systems Magazine, Vol. 14, September 1999, pp. 43-46. (pdf)
77 :  F. Maloberti, C. Gang: "Performing arithmetic functions with the Chinese abacus approach"; IEEE Transactions on Circuits and Systems II: Analog and Digital Signal Processing, Vol. 46, Issue 12, December 1999, pp. 1512-1515. (pdf)
78 :  P. Malcovati, F. Maloberti: "An Integrated Microsystem for 3D Magnetic Field Measurements"; IEEE Transactions on Instrumentation and Measurement, Vol. 49, No. 2, April 2000 pp. 341-345, 2000. (pdf)
79 :  C. Fiocchi, U. Gatti, F. Maloberti: "Design issues on high-speed high-resolution track-and-hold in BiCMOS technology"; IEE Proc. Circuits Devices Syst., Vol. 147, 2000, pp. 100-106. (pdf)
80 :  S. Solis-Bustos, J. Silva-Martinez, F. Maloberti, E. Sanchez-Sinencio: "A 60dB Dynamic Range CMOS Sixth-Order 2.4 Hz Low-Pass Filter for Medical Applications,"; IEEE Trans. on Circuits and Systems II: Analog and Digital Signal Processing, Vol. 47, Issue 12, Dec. 2000, pp. 1391 -1398. (pdf)
81 :  F. Maloberti: "High-speed Data Converters for Communication Systems"; IEEE Circuits and Systems Magazine, Vol. 1, 2001, pp. 26-36. (pdf)
82 :  I. Greek, J. Micallef, C. Debono, P. Malcovati, F. Maloberti: "A 1 V Second Order Sigma Delta Modulator"; Analog Integrated Circuits and Signal Processing, Kluwer, Vol. 27, 2001, pp. 147-160. (pdf)
83 :  P. Malcovati, F. Maloberti, C. Fiocchi, M. Pruzzi: "Curvature compensated BiCMOS bandgap with 1-V supply voltage"; IEEE Journal of Solid State Circuits, Vol. 36, 2001, pp. 1076-1081. (pdf)
84 :  J.L. Ausin, J.F. Duque-Carrillo, G. Torelli, F. Maloberti: "Switched-capacitor bandpass filter with quasi-continuous digital Q-factor tunability"; Electronics Letters , Vol. 38, 2002, pp. 8-9. (pdf)
85 :  C.J. Debono, F. Maloberti, J. Micallef: "On the design of low-voltage, low-power CMOS analog multipliers for RF applications"; IEEE Transactions on Very Large Scale Integration (VLSI) Systems, Vol. 10, Apr 2002, pp. 168-174. (pdf)
86 :  F. Maloberti, P. Estrada, P. Malcovati, A. Valero: "Validation of data converter specifications with behavioral modeling simulations"; Measurement, Elsevier Science Ltd., Vol. 31, 2002, pp. 231-245. (pdf)
87 :  P. Malcovati, S. Brigati, F. Francesconi, F. Maloberti, P. Cusinato, A. Baschirotto: "Behavioral modeling of switched-capacitor sigma-delta modulators"; IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, Vol. 50, Issue 3, 2003, pp. 352-364. (pdf)
88 :  U. Eduri, F. Maloberti: "Online Calibration of a Nyquist-Rate Analog-to-Digital Converter Using Output Code-Density Histograms"; IEEE Transactions on Circuits and Systems I: Regular Papers, Vol. 51, Issue 1, 2004, pp. 15-24. (pdf)
89 :  S. Brigati, F. Francesconi, P. Malcovati, F. Maloberti: "A Fourth-Order Single-Bit Switched-Capacitor Σ-Δ Modulator for Distributed Sensor Applications"; IEEE Transactions on Instrumentation and Measurement, Vol. 53, Issue 2, 2004, pp. 266-270. (pdf)
90 :  K.-S. Lee, F. Maloberti: "Time-interleaved sigma-delta modulator using output prediction scheme"; IEEE Transactions on Circuits and Systems II: Express Briefs, Vol. 51, Issue 10, Oct. 2004, pp. 537-541. (pdf)
91 :  V. Ferragina, A. Fornasari, U. Gatti, P. Malcovati, F. Maloberti: "Gain and Offset Mismatch Calibration in Time-Interleaved Multipath A/D Sigma-Delta Modulators"; IEEE Transactions on Circuits and Systems I: Regular Papers, Vol. 51, Issue 12, Dec. 2004, pp. 2365-2373. (pdf)
92 :  K.-S. Lee, Y. Choi, F. Maloberti: "SC amplifier and SC integrator with an accurate gain of 2"; IEEE Transactions on Circuits and Systems II: Express Briefs, Vol. 52, Issue 4, April 2005, pp. 194-198. (pdf)
93 :  K.-S. Lee, Y. Choi, F. Maloberti: "Domino free 4-path time-interleaved second order sigma-delta modulators"; Analog Integrated Circuits and Signal Processing, Vol. 43, Issue 3, June 2005, pp. 225-236. (pdf)
94 :  S. Marabelli, A. Fornasari, P. Malcovati, F. Maloberti: "An 80-MHz, 14-bit bandpass mash sigma-delta/pipeline A/D converter with 5MHz bandwidth for third order generation mobile communication systems"; Measurement, Elsevier, Vol. 37, 2005, pp. 320-327. (pdf)
95 :  J. Li, F. Maloberti: "Pipeline of Successive Approximation Converters with Optimum Power Merit Factor"; Analog Integrated Circuits and Signal Processing, Springer Science, 2005, Vol. 45, pp. 211-217. (pdf)
96 :  J. Yu, F. Maloberti: "A Low-Power Multi-bit ΣΔ Modulator in 90-nm Digital CMOS without DEM"; IEEE Journal of Solid State Circuits, Vol. 40, Issue 12, December 2005, pp. 2428-2436. (pdf)
97 :  D. Aksin, M. Al-Shyoukh, F. Maloberti: "Switch Bootstrapping for Precise Sampling Beyond Supply Voltage"; IEEE Journal of Solid State Circuits, Vol. 41, Issue 8, August 2006, pp. 1938-1943. (pdf)
98 :  G. Bernardinis, F. Borghetti, V. Ferragina, A. Fornasari, U. Gatti, P. Malcovati, F. Maloberti: "A wide-band 280-MHz four-path time-interleaved bandpass sigma-delta modulator"; IEEE Transactions on Circuits and Systems I: Regular Papers, Vol. 53, Issue 7, July 2006, pp. 1423-1432. (pdf)
99 :  A. Agnes, A. Cabrini, F. Maloberti, G. Martini: "Cancellation of Amplifier Offset and 1/? Noise: An Improved Chopper Stabilized Technique"; IEEE Transactions on Circuits and Systems II: Express Briefs, Vol. 54, Issue 6, June 2007, pp. 469-473. (pdf)
100:  K.-S. Lee, S. Kwon, F. Maloberti: "A Power-Efficient Two-Channel Time-Interleaved ΣΔ Modulator for Broadband Applications"; IEEE Journal of Solid State Circuits, Vol. 42, June 2007, pp. 1206-1215. (pdf)
101:  C. Falconi, E. Martinelli, C. Di Natale, A. D'Amico, F. Maloberti, P. Malcovati, A. Baschirotto, V. Stornelli, G. Ferri: "Electronic Interfaces"; Sensors and Actuators, B, Vol. 121, 2007, pp. 295-329. (pdf)
102:  L. Picolli, A. Rossini, P. Malcovati, F. Maloberti, F. Borghetti, A. Baschirotto: "A Clock-Less 10bit Pipeline-Like A/D Converter for Self-Triggered Sensors"; IEEE Journal of Solid-State Circuits, Vol. 43, Issue: 2, Feb. 2008, pp. 312-320. (pdf)
103:  I. Galdi, E. Bonizzoni, P. Malcovati, G. Manganaro, F. Maloberti: "40 MHz IF 1 MHz Bandwidth Two-Path Bandpass ΣΔ Modulator with 72 dB DR Consuming 16 mW" IEEE Journal of Solid-State Circuits, Vol. 43, No. 7, July 2008, pp. 1648-1656. (pdf)
104:  E. Bilhan, F. Maloberti: "A Wideband Sigma-Delta Modulator With Cross-Coupled Two-Paths"; IEEE Transactions on Circuits and Systems I: Regular Papers, Vol. 56, No. 5, May 2009, pp. 886-893. (pdf)
105:  J.Y. Wu, Z. Zhang, R. Subramonian, F. Maloberti: "A 107.4 dB SNR Multi-Bit Sigma Delta ADC With 1-PPM THD at -0.12 dB From Full Scale Input"; IEEE Journal of Solid-State Circuits, Vol. 44, No. 11, November 2009, pp. 3060-3066. (pdf)
106:  E. Bonizzoni, F. Borghetti, P. Malcovati, F. Maloberti: "A 200-mA, 93% peak power efficiency, single-inductor, dual-output DC–DC buck converter"; Analog Integrated Circuits and Signal Processing, Vol. 62, No. 2, February 2010, Springer Netherlands, pp. 121-129. (pdf)
107:  A. Fornasari, F. Borghetti, P. Malcovati, F. Maloberti: "A second-order multi-bit ΣΔ modulator with on-line calibration and digital correction of the digital-to-analog converter mismatches"; Analog Integrated Circuits and Signal Processing, Vol. 62, No. 2, February 2010, Springer Netherlands, pp. 193-204. (pdf)
t
发表于 2011-1-17 13:02:37 | 显示全部楼层
could you plz package these papers and send it to me?
Email: bsa622@sohu.com
Thank you for helping
发表于 2011-1-17 17:06:08 | 显示全部楼层
good reference & infromation !!!
 楼主| 发表于 2011-1-17 17:11:53 | 显示全部楼层
附件:
网速比较慢,剩下的明天继续
1-20.rar
13.87 MB, 下载次数: 187 , 下载积分: 资产 -5 信元, 下载支出 5 信元
21-30.rar
14.05 MB, 下载次数: 484 , 下载积分: 资产 -5 信元, 下载支出 5 信元
31-41.rar
8.03 MB, 下载次数: 796 , 下载积分: 资产 -4 信元, 下载支出 4 信元
42-50.rar
13.08 MB, 下载次数: 494 , 下载积分: 资产 -5 信元, 下载支出 5 信元
发表于 2011-1-17 20:02:00 | 显示全部楼层
谢谢分享
 楼主| 发表于 2011-1-21 14:52:35 | 显示全部楼层
第二部分,余下的下次上传
 楼主| 发表于 2011-1-24 11:20:42 | 显示全部楼层
91-100.rar (7.06 MB , 下载次数: 125 ) 71-90.rar (12.61 MB , 下载次数: 599 )
 楼主| 发表于 2011-1-24 12:05:35 | 显示全部楼层
发表于 2011-1-24 21:51:14 | 显示全部楼层
haoduoa
发表于 2011-7-6 11:50:43 | 显示全部楼层
thank you very much! it is useful!
GMT+8, 2025-12-21 07:08 , Processed in 0.031032 second(s), 8 queries , Gzip On, Redis On.
