查看: 8114|回复: 12
[解决] Fail to run RVDS v4.0 on RedHat Enterprise Linux 5.4 解决方法
发表于 2011-1-13 21:06:04 | 显示全部楼层 |阅读模式
I follow the offical rvds_install_guide to install RVDS v4.0 on RHEL x86 5.4, using both "Wizard" and "command line", the install process is smooth and seems success. But when I try to execute "ARM Workbench IDE v4.0, it always failed with a JVM problem. Please refer the the attached pictures and log for details.
Has anyone encountered this problem? Any suggestion is appreciated. Thanks.
回答:
"Eclipse 3.3 depends upon Firefox for its HTML rendering and has a dependancy on libxul.so. As Eclipse 3.3 is fairly old, it expects Firefox 1.5 or 2.0 and not the Firefox 3.0 that is installed in Centos 5.2. The workaround is to install Firefox 2.0 and set an environment variable, MOZILLA_FIVE_HOME to that installation directory.
参考 http://forums.arm.com/index.php? ... nterprise-linux-54/
发表于 2011-1-15 12:12:22 | 显示全部楼层
i've met the same problem, thanks for your info. u r so kind~~~~
 楼主| 发表于 2011-1-15 15:57:39 | 显示全部楼层
回复 2# sunfire
how debug program on the arm board. which jtag soft you are using
my board is qq2440, i do not know how to use them in RVDS 4
发表于 2011-1-29 15:50:00 | 显示全部楼层
谢谢!
发表于 2011-2-25 13:15:18 | 显示全部楼层
请问谁有RedHat Enterprise Linux AS4,发一份上来
发表于 2011-3-17 08:54:48 | 显示全部楼层
费了好大的劲弄了一个RedHat Enterprise Linux AS4,终于安装成功了.
发表于 2011-3-17 08:57:24 | 显示全部楼层
现在我把我的license上传一下,只要更改路径就可以了。
发表于 2011-7-14 18:56:10 | 显示全部楼层
太好了。。哈哈哈哈
发表于 2011-10-19 14:57:34 | 显示全部楼层
发表于 2011-12-11 06:41:17 | 显示全部楼层
回复 7# liuxinghuixjtu
    can't see your lic file
GMT+8, 2025-12-27 01:28 , Processed in 0.029036 second(s), 6 queries , Gzip On, Redis On.
