查看: 18839|回复: 15
[原创] 今天早上复习了DPI,发现cadence的sysverilog.pdf上gcc编译c语言少了个选项
发表于 2010-12-29 11:44:23 | 显示全部楼层 |阅读模式
今天又重新拾起cosim,却发现怎么编译都报错,找了之前的ppt,又仔细观摩了NCsystemverilog.pdf,就是不行,老是报这个错误:
icds:liawang@shaltc01:[~/nc_prj/nc_dpi_first]> ncsim -sv_lib hello hello
ncsim: 09.20-s016: (c) Copyright 1995-2010 Cadence Design Systems, Inc.
ncsim: *W,NOLDPI: Unable to load hello.
OSDLERROR: ./hello.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library..
ncsim: *F,NOFDPI: Function pass_string_c not found in any of the shared object specified with -SV_LIB switch.
我简直头大,一切都是按照Cadencesysverilog.pdf来的啊,怎么就能出错呢??
ncvlog -sv hello.sv
ncelab -access +RWC hello
gcc -fPIC -shared -o libdpi.so hello.c -I /tools/ius-9.20.016/tools/inca/include
ncsim -messages hello
显然是c语言文件生成的so文件没有被ncsim正确load,那么问题出在哪儿呢?问题大概出现在gcc的编译选项上。后来看了之前自己的笔记,发现这个gcc的编译选项漏了-m32,加上以后真的就好了!!
ncsim> run
DPI: pass it ON
Exported Verilog String=
string passed from C
Verilog: C: give up a string
Gimme String
Simulation complete via $finish(1) at time 0 FS + 0
./hello.sv:22
$finish;
ncsim> exit
下面两个文件分别是设计文件和c文件,后面还有在nc环境下的仿真命令:
//hello.sv
module hello();
import "DPI-C" context pass_string_c= task pass_string_sv(input string a);
import "DPI-C" context string_c2v_c= function string string_c2v_sv();
string some_string;
// This doesnt work in IUS583, will work in IUS6.0
export "DPI-C" print_string_c = function print_string_sv;
function void print_string_sv(input string aaa);
$display("Exported Verilog String=
%s", aaa);
endfunction
initial
begin
some_string = "pass it ON";
// enable when running IUS6.0
pass_string_sv(some_string);
// pass string to C
$display("Verilog: %s \n", string_c2v_sv() );
// get string from C
$finish;
end
endmodule
//hello.c
#include <stdio.h>
#include <svdpi.h>
// to use io_printf (prints to ncsim.log)
#include <veriuser.h>
void pass_string_c(const char* a) {
io_printf("DPI: %s\n", a);
// now call exported function
print_string_c("string passed from C");
// This wont work in IUS583
const char* string_c2v_c(void) {
io_printf("C: give up a string\n");
return "Gimme String";
//cmd
ncvlog -sv hello.sv
gcc -m32 -fPIC -shared -o libdpi.so hello.c -I /tools/ius-9.20.016/tools/inca/include
我还没来得及看-m32选项的作用,希望大家能够顺利cosim
 楼主| 发表于 2010-12-29 12:20:05 | 显示全部楼层
补充一句,sysverilog.pdf里还提供一种一步仿真的方法,就是这个命令:
irun hello.sv hello.c
这个对入门者比较简单,呵呵
发表于 2010-12-31 12:48:58 | 显示全部楼层
谢谢你的文章,正在研究DPI,有机会多多讨论。
发表于 2011-1-16 23:05:49 | 显示全部楼层
好东西啊 nice~~
发表于 2011-1-31 09:57:33 | 显示全部楼层
pei fu ,pei fu
发表于 2012-4-10 10:47:24 | 显示全部楼层
这里的.so文件应该是编译完的链表文件吧,是不是不能直接运行的那种?
发表于 2012-4-10 22:23:37 | 显示全部楼层
.so是库文件
发表于 2012-12-4 16:34:43 | 显示全部楼层
Cadence的sysverilog.pdf, 能上传一下吗?
发表于 2012-12-6 16:02:25 | 显示全部楼层
研究DPI中,可以多多讨论。
发表于 2012-12-7 14:31:32 | 显示全部楼层
nice good
GMT+8, 2025-12-9 16:47 , Processed in 0.028811 second(s), 5 queries , Gzip On, Redis On.
