查看: 4453|回复: 4
[求助] 电流镜MOS管的M越大,匹配就越好吗?
发表于 2010-12-23 17:57:19 | 显示全部楼层 |阅读模式
书上说,WL越大,匹配越好,如果WL一定,M越大,整体L的误差就会越小吗?
例如:L=1u W=10u M=2 和L=1u W=5u M=4,哪个匹配度好?
发表于 2010-12-23 19:29:55 | 显示全部楼层
WL一定的情况下,over drive电压越大越好
发表于 2010-12-23 19:40:52 | 显示全部楼层
管子个数越多,接触孔就越多,可以减少接触电阻和电容,使匹配更好
发表于 2010-12-24 13:00:35 | 显示全部楼层
二楼正解
发表于 2010-12-24 18:08:55 | 显示全部楼层
Both cases have L = 1 um
Area of case 1: 20 um^2
Area of case 2: 20 um^2
Both cases have the same area, and almost identical overdrive voltage (Vgs - Vt), under the same bias current.
I don't think the mismatches make much differences.  (From engineering point of view, my answer is no obsevable differences.)
GMT+8, 2025-12-23 10:53 , Processed in 0.016869 second(s), 5 queries , Gzip On, Redis On.
