查看: 2774|回复: 0
[求助] 菜鸟求助:systemc实现1/4占空比分频
发表于 2010-12-17 14:10:50 | 显示全部楼层 |阅读模式
编译过程老是出错,我都不知道怎么回事,有没有好心人来帮忙看看?如下:
//fdiv.h文件
#ifndef _DIV_H
#define _DIV_H
#include "systemc.h"
SC_MODULE(fdiv){
    sc_in<bool> clk_in;
    sc_out<bool> clk_out;
    sc_signal<bool> fdiv_tmp;
    void do_fdiv(){
        fdiv_tmp = !fdiv_tmp;
    void gen_out(){
        clk_out=(clk_in&fdiv_tmp);
    SC_CTOR(fdiv){
        fdiv_tmp=0;
        SC_METHOD(do_fdiv);
        sensitive_pos<<clk_in;
        SC_METHOD(gen_out);
        sensitive<<clk_in<<fdiv_tmp;
#endif
//fdiv.cpp文件
#include <systemc.h>
#include "fdiv.h"
int sc_mian(int,char**){
    sc_clock clk_s("clk_source",20,SC_NS);
    sc_signal<bool>clk_out;
    fdiv fdiv1("fdiv1");
    fdiv1.clk_in(clk_s);
    fdiv1.clk_out(clk_out);
    sc_trace_file *tf;
    tf=sc_create_vcd_trace_file("fdiv");
    sc_trace(tf,clk_s,"clock_source");
    sc_trace(tf,clk_out,"clk_div");
    sc_start(200);
    sc_close_vcd_trace_file(tf);
    return 0;
//出错信息
error C2678: binary '!' : no operator defined which takes a left-hand operand of type 'class sc_core::sc_signal<bool>' (or there is no acceptable conversion)
//修改状态及其出错信息
将fdif.h中        fdiv_tmp = !fdiv_tmp; 修改为fdiv_tmp = ~fdiv_tmp;  或者  fdiv_tmp.write( ~fdiv_tmp.read());
SystemC.lib(sc_main_main.obj) : error LNK2001: unresolved external symbol _sc_main
Debug/fdiv.exe : fatal error LNK1120: 1 unresolved externals
有没有人来指点一下呀?
GMT+8, 2025-12-30 03:36 , Processed in 0.014961 second(s), 5 queries , Gzip On, Redis On.
