查看: 6896|回复: 4
[原创] CC Error - Module 'NOR2X0' is not defined. (MWNL-297)
发表于 2010-12-16 10:17:25 | 显示全部楼层 |阅读模式
Hi everyone,
I met an error when I run ICC with the instruction "import_design", shown as following:
icc_shell> import_designs -format verilog -top ChipTop -cel ChipTop_floorplan {./results/compile.v}
Loading db file '/iggroup/home/phuang/Synopsys_Curriculu/low_power_methodology/lpmm_labs/lpmm_lab3/models/saed90nm_typ_ht_pg.db'
Warning: Conflict unit found: MW tech file capacitance unit is pF; Main Library capacitance unit is fF. (IFS-007)
Warning: Conflict unit found: MW tech file resistance unit is kOhm; Main Library resistance unit is MOhm. (IFS-007)
Loading db file '/iggroup/home/phuang/Synopsys_Curriculu/low_power_methodology/lpmm_labs/lpmm_lab3/models/saed90nm_min_pg.db'
Loading db file '/iggroup/home/phuang/Synopsys_Curriculu/low_power_methodology/lpmm_labs/lpmm_lab3/models/saed90nm_max_pg.db'
Loading db file '/CAD/Synopsys/ICC_vC-2009.06-SP4/libraries/syn/gtech.db'
Loading db file '/CAD/Synopsys/ICC_vC-2009.06-SP4/libraries/syn/standard.sldb'
***** Verilog HDL translation! *****
***** Start Pass 1 *****
Begin loading DB for bus info.
End of loading DB for bus info.Elapsed = 0:00:00, CPU = 0:00:00
Warning: All isolation_upf and retention_upf pragmas are ignored. (VER-282)
***** Pass 1 Complete *****
Elapsed = 0:00:01, CPU = 0:00:00
***** Start Pass 2 *****
Error: Module 'NOR2X0' is not defined. (MWNL-297)
hdlCleanupDBLibrary:
Error: Verilog parser cannot parse the /iggroup/home/phuang/Synopsys_Curriculu/low_power_methodology/lpmm_labs/lpmm_lab3/results/compile.v source file. (MWNL-047)
No such file or directory
Error: Current design is not defined. (UID-4)
0
icc_shell>
Following the the manual of MWNL-297, I checked my netlist file and the FRAM reference library, both of them contain the module 'NOR2X0' .
So how to deal with the problem? I am puzzled.
looking forward to your advice. Thanks a lot!
发表于 2012-9-2 21:06:30 | 显示全部楼层
the same question!!!!
发表于 2012-9-2 21:58:56 | 显示全部楼层
这个应该要被移到讨论区吧,而且都是两年前的问题了!
这个问题应该是reference library没有fram!
发表于 2014-9-12 12:28:45 | 显示全部楼层
回复 3# zg8312
   在add  reference libraries时  add了 sc  其中不就有 cell跟farm吗
发表于 2020-6-22 17:49:24 | 显示全部楼层
求问怎么解决的
GMT+8, 2025-12-25 01:04 , Processed in 1.148327 second(s), 7 queries , Gzip On, Redis On.
