查看: 12111|回复: 13
请问.25um的Gate:Area是多少? (等效单元门面积?).35um?
发表于 2005-7-11 09:35:03 | 显示全部楼层 |阅读模式
.35um的Gate:Area是多少? (等效单元门面积?)
我知道.18um的Gate:Area是8.92212
发表于 2005-7-11 16:03:57 | 显示全部楼层
Different Fab and ASIC lib has different area.
发表于 2005-7-11 17:04:58 | 显示全部楼层
我记得:
.25 => 17 左右。
.18 => 10 左右.
可以自己算!
The gate count of a particular library cell corresponds with the function
of the standard gate count of the NAND-gate area in the technology library.
For example, if the NAND-gate cell area is specified as 23 in the technology
library and the flip-flop area is defined as 138, the total gate count of the
flip-flop is 138/23 or 6.
Similarly, the gate count of a design is the area of a design divided by
the gate count of the NAND gate (as defined in the technology library).
This number is the area of the NAND gate. To obtain the area of the design,
use the report_area command in Design Compiler. To find the total gate
count of the design, divide the cell area by the area of the NAND gate.
 楼主| 发表于 2005-7-11 17:26:05 | 显示全部楼层
用的是tsmc的.25um, synopsys lib
 楼主| 发表于 2005-7-18 14:40:15 | 显示全部楼层
[这个贴子最后由Jeff168在 2005/07/18 05:57pm 第 1 次编辑]
直接看综合后的cell报告文件中的 NAND2X1 或NOR2XL表示的值就是? 比如17
发表于 2005-7-18 17:38:51 | 显示全部楼层
下面引用由Jeff1682005/07/18 02:40pm 发表的内容:
直接看综合后的cell报告文件中的 NAND2X1 或NOR2XL表示的值就是? 比如17.28
对,很简单,你做一个与非逻辑,然后report一下就可以了。
 楼主| 发表于 2005-7-18 17:50:17 | 显示全部楼层
[这个贴子最后由Jeff168在 2005/07/18 05:59pm 第 1 次编辑]
    谢谢以上各位与斑竹!
  i think "report中的值"与"设计后期实际得出的的比值"会有些微小的差值,
比如report中的值为17,实际值为18或19.
发表于 2005-7-23 12:37:55 | 显示全部楼层
SMIC 0.18 NAND 10.1um2
发表于 2008-7-27 15:55:19 | 显示全部楼层
谢谢各位楼上的讨论,让我对面积报告有了清楚的认识,赞!
发表于 2008-10-28 09:01:43 | 显示全部楼层
如果是90nm的工艺,等效面积是多少喃?
GMT+8, 2025-12-27 09:25 , Processed in 0.023968 second(s), 6 queries , Gzip On, Redis On.
