楼主 |
发表于 2010-12-12 00:01:15
显示全部楼层
元件声明:
component vga_controller_stream is
port(
address:IN std_logic;
clk :IN std_logic;
reset :IN std_logic;
chipselect: IN std_logic;
enwrite: IN std_logic;
writedata:in std_logic_vector(7 downto 0);
readyfordata: out std_logic;
endofpacket ut std_logic;
hsync: out std_logic;
vsync: out std_logic;
rgb: out std_logic_vector(7 downto 0)
错误行:
DUT : vga_controller_stream PORT MAP(address => address, clk => clk, reset => reset,chipselect => chipselect,enwrite => enwrite,writedata => writedata,readyfordata => readyfordata,endofpacket => endofpacket,hsync => hsync,vsync => vsync, rgb => rgb);
顶层文件为verilog的:
接口说明为:
module vga_controller_stream(
clk,reset,chipselect,enwrite,writedata,readyfordata,endofpacket,address,hsync,vsync,rgb);
input address;
input clk;
input reset;
input chipselect;
input enwrite;
input[7:0] writedata;
output readyfordata;
output endofpacket;
output hsync;
output vsync;
output[7:0] rgb;
没有问题吧!!? |
