查看: 6460|回复: 27
[资料] 一本高清英文原版书:Electronic Digital System Fundamentals
发表于 2010-12-10 20:02:27 | 显示全部楼层 |阅读模式
文章内容介绍:Chapters
1 Introduction to digital systems  ........................................................... 1
  2 Digital logic gates  ................................................................................ 31
  3 Boolean algebra and logic gates ......................................................... 49
  4 Combinational logic gates  ................................................................. 97
  5 Number systems, conversions and codes  ...................................... 133
  6 Binary addition and subtraction  ..................................................... 153
  7 Digital timing and signals  ................................................................ 185
  8 Sequential logic gates  ....................................................................... 215
  9 Counters and shift registers  ............................................................. 237
  10 Data conversion  ................................................................................. 267
  11 Advanced digital concepts  .............................................................. 293
Appendices
A—Electrical and electronic safety .............................................................. 313
B—Datasheets ................................................................................................. 325
C—Constructing digital circuits .................................................................. 327
Index ................................................................................................................ 337
preface
Electronic Digital Systems Fundamentals is an introductory text that
provides coverage of the various topics in the field of digital electronics.
The key concepts presented in this book are discussed using a simplified
approach that greatly enhances learning. The use of mathematics is kept
to the very minimum and is discussed clearly through applications and
illustrations.
  Each chapter is organized in a step-by-step progression of concepts
and theory. The chapters begin with an introduction, discuss important
concepts with the help of numerous illustrations, as well as examples, and
conclude with summaries.
  The overall learning objectives of this book include:
• Describe the characteristics of a digital electronic system.
• Explain the operation of digital electronic gate circuits.
• Demonstrate how gate functions are achieved.
• Use binary, octal, and hexadecimal counting systems.
• Use Boolean algebra to define different logic operations.
• Change a logic diagram into a Boolean expression and a Boolean
expression into a logic diagram.
• Explain how discrete components are utilized in the construction of
digital integrated circuits.
• Discuss how counting, decoding, multiplexing, demultiplexing, and
clocks function with logic devices.
•  Change a truth table into a logic expression and a logic expression
into a truth table.
• Identify some of the common functions of digital memory.
• Explain how arithmetic operations are achieved with digital
circuitry.
Appendices are also included that contain information regarding
circuit symbols, data sheets and electrical safety.
The authors hope that you will find Electronic Digital System
Fundamentals easy to understand and that you are successful in your
pursuit of knowledge in this exciting technical area.
喜欢的tx下载看看吧!
Electronic Digital System Fundamentals.pdf
4.56 MB, 下载次数: 207 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2010-12-10 21:13:37 | 显示全部楼层
thanks!
发表于 2010-12-10 21:33:10 | 显示全部楼层
回复 1# pio123
    谢谢!!
发表于 2010-12-10 21:34:04 | 显示全部楼层
good, thanks.
发表于 2010-12-11 08:46:23 | 显示全部楼层
呵呵,谢谢楼主
发表于 2010-12-11 09:22:44 | 显示全部楼层
thanks.
发表于 2010-12-11 09:39:33 | 显示全部楼层
路过,支持!
发表于 2010-12-11 09:45:25 | 显示全部楼层
谢谢分享啊
发表于 2010-12-11 15:09:00 | 显示全部楼层
好书 ,谢谢楼主
发表于 2010-12-11 16:49:24 | 显示全部楼层
i think that is good
GMT+8, 2025-11-10 04:32 , Processed in 0.023263 second(s), 6 queries , Gzip On, Redis On.
