查看: 4463|回复: 14
[资料] Essentials of UMTS
发表于 2010-12-7 13:59:38 | 显示全部楼层 |阅读模式
Essentials of UMTS
Publisher: Cambridge University Press
Pages: 256
Date: 2008-11-10
Format: PDF
Abstract:
The third generation (3G) cellular system UMTS is advanced, optimised and complex. The many existing books on UMTS attempt to explain all the intricacies of the system and as a result are large and equally complex. This book takes a different approach and explains UMTS in a concise, clear and readily understandable style. Written by a professional technical trainer, and based on training courses delivered on UMTS to telecommunication companies worldwide, Essentials of UMTS will enable you to grasp the key concepts quickly. It assumes no previous knowledge of mobile telecommunication theory, and is structured around the operation of the system, clearly setting out how the different components interact with each other, and how the system as a whole behaves. Engineers, project managers and marketing executives working for equipment manufacturers and network operators will find this concise guide to UMTS invaluable.
Essentials of UMTS.pdf (3.52 MB , 下载次数: 88 )
发表于 2010-12-8 08:15:18 | 显示全部楼层
下来看看,谢谢。
发表于 2010-12-8 09:54:44 | 显示全部楼层
下来看看,谢谢,根据简介,是个入门级的培训课程教材。
发表于 2010-12-8 14:50:47 | 显示全部楼层
haha ,thanks
发表于 2010-12-8 14:55:47 | 显示全部楼层
回复 4# dtlcyang
发表于 2010-12-8 14:58:27 | 显示全部楼层
thanks a lot
发表于 2010-12-8 15:08:52 | 显示全部楼层
回复 6# dtlcyang
    11
发表于 2010-12-8 15:17:04 | 显示全部楼层
thank you so much
头像被屏蔽
发表于 2010-12-8 19:26:23 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-12-8 23:14:43 | 显示全部楼层
thanks!
GMT+8, 2025-12-3 18:03 , Processed in 0.021956 second(s), 6 queries , Gzip On, Redis On.
