查看: 5234|回复: 13
[原创] pll设计资料大全
发表于 2010-12-2 22:21:02 | 显示全部楼层 |阅读模式
abbr_fb7a07437b95dd1e36ca08c17c96ad0d.pdf (595.01 KB , 下载次数: 16 ) abbr_fb7a07437b95dd1e36ca08c17c96ad0d.pdf (595.01 KB , 下载次数: 15 ) Predicting the Phase Noise and Jitter of PLL-Based Frequency Synthesizers.pdf (659.51 KB , 下载次数: 7 ) abbr_131b32058fe0b633313659c8a8387773.pdf (318.79 KB , 下载次数: 12 ) A Q-factor enhancement technique for MMIC inductors .pdf (395.59 KB , 下载次数: 5 ) Analysis, design, and optimization of spiral inductors and transformers for Si RF ICs .pdf (345.37 KB , 下载次数: 7 ) abbr_694d37331260e01057f30c11022772c0.pdf (422.91 KB , 下载次数: 7 ) abbr_d8e0101b3b5607c2493c251716b651b0.pdf (116.91 KB , 下载次数: 7 ) On the use of MOS varactors in RF VCOs .pdf (202.8 KB , 下载次数: 8 ) On-chip spiral inductors with patterned ground shields for Si-based RF ICs .pdf (247.34 KB , 下载次数: 6 ) abbr_36bf2fc892d2362133d79094c6c8da7f.pdf (118.47 KB , 下载次数: 4 ) Stacked inductors and transformers in CMOS technology.pdf (315.37 KB , 下载次数: 4 ) Substrate noise coupling through planar spiral inductor .pdf (279.05 KB , 下载次数: 5 ) abbr_d86d6e267d94027ef272f853cfd52396.pdf (115.94 KB , 下载次数: 6 ) abbr_e4657dc3fe7224a6b90e36fb192691f8.pdf (376.42 KB , 下载次数: 5 )
The Effect of Varactor Nonlinearity on the Phase Noise of Completely Integrated VCOs.pdf
274.64 KB, 下载次数: 12 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A General Theory of Phase Noise in Electrical Oscillators.pdf
479.66 KB, 下载次数: 4 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A Study of Oscillator Jitter Due to Supply and Substrate Noise.pdf
218.72 KB, 下载次数: 4 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A Study of Phase Noise in CMOS Oscillators.pdf
1.3 MB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Jitter and Phase Noise in Ring Oscillators.pdf
745.42 KB, 下载次数: 18 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Jitter in Ring Oscillators.pdf
270.28 KB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Low-noise voltage-controlled oscillators using enhanced LC-tanks.pdf
892.4 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Measurements and Analysis of PLL Jitter Caused by Digital Switching Noise.pdf
120.74 KB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
On-Chip Measurement of the Jitter Transfer Function of Charge-Pump Phase-Locked Loops.pdf
184.51 KB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Phase Noise in LC Oscillators.pdf
86.95 KB, 下载次数: 4 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Physical Processes of Phase Noise in Differential LC Oscillators.pdf
333.56 KB, 下载次数: 27 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-12-2 22:25:42 | 显示全部楼层
内容主要包括:
Part1 - Introduction;
Part2 - Devices;
Part3 - Phase Noise and Jitter;
Part4- Clock Generation and PLL DLL;
Part5 - RF Synthesis;
目前上传只完成Part3。
 楼主| 发表于 2010-12-2 22:32:51 | 显示全部楼层
接着上传剩余的内容:
Low-jitter process-independent DLL and PLL based on self-biased techniques .pdf
1.05 MB, 下载次数: 47 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_aae4062456a7d4b2744bbdc77c8d58fc.pdf
501.36 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A 320 MHz, 1.5 mW@1.35 V CMOS PLL for microprocessor clock generation .pdf
811.88 KB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A 960-Mb,s,pin interface for skew-tolerant bus using low jitter PLL .pdf
218.02 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A dual-loop delay-locked loop using multiple voltage-controlled delay lines .pdf
230.3 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A low jitter 0.3-165 MHz CMOS PLL frequency synthesizer for 3 V,5 V operation .pdf
101.17 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_495e1c2dccba4bbc7a3efe87522391a5.pdf
420.84 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A low-jitter PLL clock generator for microprocessors with lock range of 340-612 MHz .pdf
666.34 KB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_74c6d2c35af753f5a67dd4550d64a482.pdf
411.97 KB, 下载次数: 1 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A low-noise fast-lock phase-locked loop with adaptive bandwidth control .pdf
444.76 KB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A portable digital DLL for high-speed CMOS interface circuits .pdf
546.5 KB, 下载次数: 9 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A register-controlled symmetrical DLL for double-data-rate DRAM .pdf
67.6 KB, 下载次数: 9 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A semidigital dual delay-locked loop .pdf
266.42 KB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A wide-range delay-locked loop with a fixed latency of one clock cycle .pdf
315.43 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Active GHz clock network using distributed PLLs .pdf
287.97 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_c1c0c957a85d96b598105fbdfd4f5970.pdf
260.99 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_84894c4ede2fc19a8536e0b4812e7453.pdf
146.26 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Low-power dividerless frequency synthesis using aperture phase detection .pdf
194.83 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_46677bdd8405fa43036fc4adb73f8b47.pdf
319.74 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A 1.8-GHz self-calibrated phase-locked loop with precise IQ matching .pdf
248.4 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A 1.76-GHz 22.6-mW spl Deltaspl Sigma fractional-n frequency synthesizer .pdf
300.7 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A 2.6-GHz,5.2-GHz frequency synthesizer in 0.4-μm CMOS technology .pdf
199.47 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A 2-V 900-MHz monolithic CMOS dual-loop frequency synthesizer for GSM receivers .pdf
295.45 KB, 下载次数: 15 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_56798674dd6cac9de7a3acca52808306.pdf
360.45 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_ce10a6df20e5b2a974543ab027feac13.pdf
351.65 KB, 下载次数: 4 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_d02be3e65ba0a7ca2bc0422f0425a80e.pdf
289.29 KB, 下载次数: 2 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A CMOS monolithic ΔΣ-controlled fractional-N frequency synthesizer for DCS-1800 .pdf
496.77 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_26f7fe01f83de6e75d6dd16b438ade0a.pdf
309.02 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_f0c0b697b38cf9b1241c3f18c283532c.pdf
420.47 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A stabilization technique for phase-locked frequency synthesizers .pdf
630.71 KB, 下载次数: 12 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_0dbf24005233764323bf97b3c60711ff.pdf
678.69 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Fast-switching frequency synthesizer with a discriminator-aided phase detector .pdf
484.15 KB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-12-3 08:24:04 | 显示全部楼层
so many good reference at PLL
发表于 2010-12-3 08:46:16 | 显示全部楼层
呵呵,谢谢楼主
发表于 2010-12-3 09:02:45 | 显示全部楼层
呵呵,谢谢楼主
发表于 2010-12-3 11:30:53 | 显示全部楼层
下来看看,谢谢。
发表于 2010-12-4 23:00:01 | 显示全部楼层
谢谢楼主分享
发表于 2010-12-4 23:44:12 | 显示全部楼层
资料太多,花钱也多呀
发表于 2010-12-5 00:33:28 | 显示全部楼层
多是多可没有打包不方便下载
GMT+8, 2025-12-22 09:35 , Processed in 0.031864 second(s), 6 queries , Gzip On, Redis On.
