查看: 3445|回复: 1
[讨论] partition strategy for 45nm and take SI and IR-drop into consideration
发表于 2010-12-2 19:48:14 | 显示全部楼层 |阅读模式
Hi Folks
As title, is there any one have this kind of experience?
should the RTL code be in compliance with the parition in back-end?
Nicolas
发表于 2010-12-2 21:58:28 | 显示全部楼层
sure, as i know, our company would also use other tools, such as ptpx to verify SI and IR-drop issue. the common method is change the dft related logic to meet the Backend.
GMT+8, 2025-12-11 17:36 , Processed in 0.016636 second(s), 7 queries , Gzip On, Redis On.
