已最大化分割,方便大家下载,共三部分。以下是主要章节内容:
Foreword ................................................................................................................vii
Preface ....................................................................................................................ix
Acknowledgments .....................................................................................................xi
Op Amp History Highlights ...................................................................................... xv
Chapter 1: Op Amp Basics ........................................................................................3
Section 1-1: Introduction ...............................................................................................5
Section 1-2: Op Amp Topologies ..................................................................................23
Section 1-3: Op Amp Structures ...................................................................................31
Section 1-4: Op Amp Specifi cations ..............................................................................51
Section 1-5: Precision Op Amps ...................................................................................89
Section 1-6: High Speed Op Amps ................................................................................97
Chapter 2: Specialty Amplifi ers ..............................................................................121
Section 2-1: Instrumentation Amplifi ers ......................................................................123
Section 2-2: Programmable Gain Amplifi ers ................................................................151
Section 2-3: Isolation Amplifi ers .................................................................................161
Chapter 3: Using Op Amps with Data Converters ....................................................173
Section 3-1: Introduction ...........................................................................................173
Section 3-2: ADC/DAC Specifi cations .........................................................................179
Section 3-3: Driving ADC Inputs .................................................................................193
Section 3-4: Driving ADC/DAC Reference Inputs .........................................................213
Section 3-5: Buffering DAC Outputs ...........................................................................217
Chapter 4: Sensor Signal Conditioning ....................................................................227
Section 4-1: Introduction ...........................................................................................227
Section 4-2: Bridge Circuits ........................................................................................231
Section 4-3: Strain, Force, Pressure and Flow Measurements .......................................247
Section 4-4: High Impedance Sensors .........................................................................257
Section 4-5: Temperature Sensors ...............................................................................285
Chapter 5: Analog Filters ......................................................................................309
Section 5-1: Introduction ...........................................................................................309
Section 5-2: The Transfer Function .............................................................................313
vi
Contents
Section 5-3: Time Domain Response ..........................................................................323
Section 5-4: Standard Responses ................................................................................325
Section 5-5: Frequency Transformations .....................................................................349
Section 5-6: Filter Realizations ....................................................................................357
Section 5-7: Practical Problems in Filter Implementation .............................................393
Section 5-8: Design Examples .....................................................................................403
Chapter 6: Signal Amplifi ers ..................................................................................423
Section 6-1: Audio Amplifi ers .....................................................................................423
Section 6-2: Buffer Amplifi ers and Driving Capacitive Loads ........................................493
Section 6-3: Video Amplifi ers .....................................................................................505
Section 6-4: Communication Amplifi ers ......................................................................545
Section 6-5: Amplifi er Ideas ........................................................................................567
Section 6-6: Composite Amplifi ers ..............................................................................587
Chapter 7: Hardware and Housekeeping Techniques .................................................607
Section 7-1: Passive Components ...............................................................................609
Section 7-2: PCB Design Issues ...................................................................................629
Section 7-3: Op Amp Power Supply Systems ...............................................................653
Section 7-4: Op Amp Protection .................................................................................675
Section 7-5: Thermal Considerations ..........................................................................699
Section 7-6: EMI/RFI Considerations ..........................................................................707
Section 7-7: Simulation, Breadboarding and Prototyping .............................................737
Chapter 8: Op Amp History ..................................................................................765
Section 8-1: Introduction ...........................................................................................767
Section 8-2: Vacuum Tube Op Amps ..........................................................................773
Section 8-3: Solid-State Modularand Hybrid Op Amps ................................................791
Section 8-4: IC Op Amps ...........................................................................................805
Index ...................................................................................................................831 |
