查看: 3813|回复: 4
[招聘] 经典IC设计面试问题7
发表于 2010-11-27 12:42:09 | 显示全部楼层 |阅读模式
What is meant by         inferring latches,how to avoid it?
Consider the following :
always @(s1 or s0 or i0 or i1 or i2 or i3)
case ({s1, s0})
2'd0 : out = i0;
2'd1 : out = i1;
2'd2 : out =         i2;
endcase
in a case statement if all the possible         combinations are not compared and default is also not specified like in         example above a latch will be inferred ,a latch is inferred because to         reproduce the previous value when unknown branch is specified.
For         example in above case if {s1,s0}=3 , the previous stored value is         reproduced for this storing a latch is inferred.
The same may be         observed in IF statement in case an ELSE IF is not specified.
To         avoid inferring latches make sure that all the cases are mentioned if         not default condition is provided.
发表于 2010-11-27 13:34:58 | 显示全部楼层
谢谢louzhu分享!
发表于 2010-11-27 23:36:11 | 显示全部楼层
张宁益
发表于 2010-11-27 23:47:18 | 显示全部楼层
dsfsdfgsdf
发表于 2011-7-18 10:59:13 | 显示全部楼层
嘿嘿,很基础,练英语了
GMT+8, 2025-12-28 10:00 , Processed in 0.028100 second(s), 5 queries , Gzip On, Redis On.
