查看: 2897|回复: 0
[讨论]在modelsim5.8 中遇到的问题
发表于 2005-7-1 11:35:58 | 显示全部楼层 |阅读模式
我在使用所提供的dff测试程序仿真时,怎么出现下面问题,难道是版本问题吗?我使用的是lattice isplever modelsim5.8,怎么解决这个问题啊
vsim work.dff
# vsim work.dff
# Licensing checkout error with feature vantmti. (Error code -21.)
# The *** file does not support this version.
# The most common cause of this error is that the ***
# file maintenance date has expired.  The maintenance date
# specifies which version of a product you can run.
# You can run versions that were released prior to your
# maintenance expiration date, but attempting to run versions
# released after your maintenance expiration date will produce
# this error.
# (Example: If the *** file maintenance date is 2000.050
# you can run only versions released during or prior to May, 2000.).
# ** Error: Failure to obtain a Verilog simulation *** .
# Error loading design
GMT+8, 2025-12-17 00:32 , Processed in 0.013435 second(s), 4 queries , Gzip On, Redis On.
