查看: 2579|回复: 3
[求助] NiosII9.0SP2 flash programmer 失败
发表于 2010-11-23 18:46:53 | 显示全部楼层 |阅读模式
知道在这里提问欠妥,但是为了得到支援,还是来了。
    我在NIOS IDE中下载SST39LF400出现下面问题,不知道为什么,请大家帮个忙,多谢!
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd D:/Nios_SDRAM_FLASH/software/hello_world_0/Debug
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00000000 --end=0xfffff --reset=0x0 --in
put="hello_world_0.elf" --output="cfi_flash_0.flash" --boot="C:/altera/90/ip/alt
era/nios2_ip/altera_nios2/boot_loader_cfi.srec"
# Programming flash with the project
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --sidp=0x00104030
--id=855840331 --timestamp=1290504184
"cfi_flash_0.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00104030: verified
: Checksumming existing contents
00000000
: Reading existing contents
Checksums took 0.0s
00000000 ( 0%): Erasing
Erased 4kB in 0.0s
00000000 ( 0%): Programming
Program failed at offset 6
Leaving target processor paused
 楼主| 发表于 2010-11-23 22:43:55 | 显示全部楼层
无人问津??
 楼主| 发表于 2010-11-24 08:57:50 | 显示全部楼层
难道真的没有人帮助吗?
发表于 2011-5-9 15:11:43 | 显示全部楼层
我也碰到了一样的问题,还没有解出来呢
GMT+8, 2025-12-29 14:49 , Processed in 0.018153 second(s), 7 queries , Gzip On, Redis On.
