查看: 6373|回复: 14
[求助] 求助 哪个版本的hspice支持verilog_A
发表于 2010-11-20 15:47:45 | 显示全部楼层 |阅读模式
请问论坛里那个版本的hspice支持 Verilog_A,请安装后成功运行过Verilog_a的高人指点一下
发表于 2010-11-20 20:35:04 | 显示全部楼层
cadence 下可以使用~~~~ 也可以到对面实验室问问~~~
 楼主| 发表于 2010-11-20 20:37:14 | 显示全部楼层
回复 2# fallzzz
你是哪位师兄啊
发表于 2010-11-20 20:37:57 | 显示全部楼层
gaoyuan说07版本支持
发表于 2010-11-20 20:42:28 | 显示全部楼层
回复 3# lihaiqi208
    你懂得~~~
发表于 2010-11-22 10:02:37 | 显示全部楼层
我闻所未闻
发表于 2010-11-22 18:43:27 | 显示全部楼层
Hspice versions 2007 and after. ...
However, the Verilog-A simulator's pre-processor does not behave the same as that from Cadence Spectre.
 楼主| 发表于 2010-11-22 18:55:15 | 显示全部楼层
回复 7# fhchen2002
论坛里我下了几个版本 都不能运行va 不知您知道什么原因(是不是我哪儿设置不对)
发表于 2010-11-24 17:58:23 | 显示全部楼层
回复 8# lihaiqi208
Question:
Did you use the following command card in your simulation deck?
.hdl abc.va $ where "abc.va" is the name of the file that contains the block that is described by Verilog-A language.
As the next step, please check the log file of your Hspice runs.
In the log file, you should see something like the following:
... Invoking the Verilog-A compiler for 'abc.va'
... Synopsys HSPICE Verilog-A Compiler version 1.YYY.ZZZZZZ.
... lic: Release hspiceva token(s)
If all the above shows up, it means your simulator is with the Verilog-A license and can bring up the Verilog-A compiler.
Good luck!
 楼主| 发表于 2010-11-25 20:08:16 | 显示全部楼层
回复 9# fhchen2002
高手您好 我仿的时候出现以下错误
** error **
During Verilog-A Device processing:
    CML file does not exist
         'C:\Users\acer\hsp-model-cache\1.83\e\\program file\hpsice1\demo\hspice\veriloga\\lib.win32\dac.cml'
** error **
    An internal system error has occurred [TDA-SYSTEM-10936]. Please contact Synopsys support.
请帮忙分析 谢谢您
GMT+8, 2025-12-20 21:22 , Processed in 0.027051 second(s), 5 queries , Gzip On, Redis On.
