查看: 23148|回复: 126
[资料] 论坛首发2010 Springer--ADC新书Generalized Low-Voltage Circuit Techniques for ...
发表于 2010-11-16 02:02:17 | 显示全部楼层 |阅读模式
Generalized Low-Voltage Circuit Techniques for Very High-Speed Time-Interleaved Analog-to-Digital Converter
Generalized Low-Voltage Circuit Techniques for Very High-Speed Time-Interleaved Analog-to-Digital Converters (Analog Circuits and Signal Processing) [Hardcover]Sai-Weng Sin (Author), Seng-Pan U (Author), Rui Paulo Martins (Author)
http://www.amazon.com/Generalized-Low-Voltage-Techniques-High-Speed-Time-Interleaved/dp/9048197090/ref=sr_1_3?s=books&ie=UTF8&qid=1289834854&sr=1-3
Editorial Reviews        Product Description    Analog-to-Digital Converters (ADCs) play an important role in most modern signal processing and wireless communication systems where extensive signal manipulation is necessary to be performed by complicated digital signal processing (DSP) circuitry. This trend also creates the possibility of fabricating all functional blocks of a system in a single chip (System On Chip - SoC), with great reductions in cost, chip area and power consumption. However, this tendency places an increasing challenge, in terms of speed, resolution, power consumption, and noise performance, in the design of the front-end ADC which is usually the bottleneck of the whole system, especially under the unavoidable low supply-voltage imposed by technology scaling, as well as the requirement of battery operated portable devices. Generalized Low-Voltage Circuit Techniques for Very High-Speed Time-Interleaved Analog-to-Digital Converters will present new techniques tailored for low-voltage and high-speed Switched-Capacitor (SC) ADC with various design-specific considerations.
      From the Back Cover    Analog-to-Digital Converters (ADCs) play an important role in most modern signal processing and wireless communication systems where extensive signal manipulation is necessary to be performed by complicated digital signal processing (DSP) circuitry. This trend also creates the possibility of fabricating all functional blocks of a system in a single chip (System On Chip - SoC), with great reductions in cost, chip area and power consumption. However, this tendency places an increasing challenge, in terms of speed, resolution, power consumption, and noise performance, in the design of the front-end ADC which is usually the bottleneck of the whole system, especially under the unavoidable low supply-voltage imposed by technology scaling, as well as the requirement of battery operated portable devices. Generalized Low-Voltage Circuit Techniques for Very High-Speed Time-Interleaved Analog-to-Digital Converters will present new techniques tailored for low-voltage and high-speed Switched-Capacitor (SC) ADC with various design-specific considerations.
Product Details
abbr_dad88a589db677df93ed91471b5d6b49.rar (3.65 MB , 下载次数: 1234 )
发表于 2010-11-16 06:23:06 | 显示全部楼层
板凳!1
发表于 2010-11-16 08:09:09 | 显示全部楼层
good reference for adc design
发表于 2010-11-16 08:10:49 | 显示全部楼层
下来看看,谢谢。
发表于 2010-11-16 08:36:53 | 显示全部楼层
谢谢楼主的分享
发表于 2010-11-16 08:41:25 | 显示全部楼层
感謝分享
发表于 2010-11-16 08:44:19 | 显示全部楼层
下载看看了
发表于 2010-11-16 08:44:51 | 显示全部楼层
download complete...
发表于 2010-11-16 12:44:52 | 显示全部楼层
wow, thanks!
发表于 2010-11-16 17:51:25 | 显示全部楼层
wow, thanks!
GMT+8, 2025-12-29 05:31 , Processed in 0.024223 second(s), 7 queries , Gzip On, Redis On.
