楼主: foveryoung
[原创] 数字集成电路(设计透视) 包括书、ppt及答案
发表于 2010-11-10 10:20:29 | 显示全部楼层
Gives the keyboard input focus to this widget (or its focus proxy) if this widget or one of its parents is the active window. The reason argument will be passed into any focus event sent from this function, it is used to give an explanation of what caused the widget to get focus. If the window is not active, the widget will be given the focus when the window becomes active.
First, a focus out event is sent to the focus widget (if any) to tell it that it is about to lose the focus. Then a focus in event is sent to this widget to tell it that it just received the focus. (Nothing happens if the focus in and focus out widgets are the same.)
发表于 2010-11-14 17:34:14 | 显示全部楼层
thanks
发表于 2010-11-16 18:46:31 | 显示全部楼层
非常需要的啊
发表于 2010-11-21 00:20:21 | 显示全部楼层
答案MS很乱呃 看不懂
发表于 2010-12-4 14:37:20 | 显示全部楼层
谢谢分享了
发表于 2010-12-4 23:13:08 | 显示全部楼层
有答案!
发表于 2010-12-5 02:25:37 | 显示全部楼层
sharing thx, thx .
发表于 2011-5-12 13:09:44 | 显示全部楼层
发表于 2011-5-12 14:24:35 | 显示全部楼层
有中文版本的就好了,可以对照的看。
发表于 2011-6-8 16:18:00 | 显示全部楼层
答案全吗
GMT+8, 2025-12-30 23:34 , Processed in 0.018197 second(s), 4 queries , Gzip On, Redis On.
