查看: 6280|回复: 3
[资料] 3GP TS 25.211
发表于 2010-11-9 03:34:32 | 显示全部楼层 |阅读模式
3rd Generation Partnership Project;
Technical Specification Group Radio Access Network;
Physical channels and mapping of transport channels
onto physical channels (FDD)
(Release 9)
The present document describes the characteristics of the Layer 1 transport channels and physicals channels in the FDD
mode of UTRA. The main objectives of the document are to be a part of the full description of the UTRA Layer 1, and
to serve as a basis for the drafting of the actual technical specification (TS).
1 Scope .................................................................................................................................................. 6
2 References .......................................................................................................................................... 6
3 Symbols, abbreviations and definitions ............................................................................................... 7
3.1 Symbols ....................................................................................................................................................... 7
3.2 Abbreviations............................................................................................................................................... 7
3.3 Definitions ................................................................................................................................................... 8
4 Services offered to higher layers ......................................................................................................... 8
4.1 Transport channels ....................................................................................................................................... 8
4.1.1 Dedicated transport channels ................................................................................................................... 8
4.1.1.1 DCH - Dedicated Channel ................................................................................................................. 8
4.1.1.2 E-DCH – Enhanced Dedicated Channel ............................................................................................. 8
4.1.2 Common transport channels .................................................................................................................... 8
4.1.2.1 BCH - Broadcast Channel .................................................................................................................. 8
4.1.2.2 FACH - Forward Access Channel ...................................................................................................... 8
4.1.2.3 PCH - Paging Channel ....................................................................................................................... 9
4.1.2.4 RACH - Random Access Channel...................................................................................................... 9
4.1.2.5 Void .................................................................................................................................................. 9
4.1.2.6 Void .................................................................................................................................................. 9
4.1.2.7 HS-DSCH – High Speed Downlink Shared Channel .......................................................................... 9
4.1.2.7A E-DCH - Enhanced Dedicated Channel .............................................................................................. 9
4.2 Indicators ..................................................................................................................................................... 9
5 Physical channels and physical signals ................................................................................................ 9
5.1 Physical signals .......................................................................................................................................... 10
5.2 Uplink physical channels ............................................................................................................................ 10
5.2.1 Dedicated uplink physical channels ....................................................................................................... 10
5.2.1.1 DPCCH and DPDCH ...................................................................................................................... 10
5.2.1.2 HS-DPCCH..................................................................................................................................... 13
5.2.1.3 E-DPCCH and E-DPDCH ............................................................................................................... 13
5.2.2 Common uplink physical channels ........................................................................................................ 15
5.2.2.1 Physical Random Access Channel (PRACH) ................................................................................... 15
5.2.2.1.1 Overall structure of random-access transmission ......................................................................... 15
5.2.2.1.2 RACH preamble part.................................................................................................................. 16
5.2.2.1.3 RACH message part ................................................................................................................... 16
5.2.2.2 Void ................................................................................................................................................ 17
5.3 Downlink physical channels ....................................................................................................................... 17
5.3.1 Downlink transmit diversity .................................................................................................................. 17
5.3.1.1 Open loop transmit diversity ............................................................................................................ 19
5.3.1.1.1 Space time block coding based transmit antenna diversity (STTD) .............................................. 19
5.3.1.1.2 Time Switched Transmit Diversity for SCH (TSTD) ................................................................... 21
5.3.1.2 Closed loop transmit diversity.......................................................................................................... 21
5.3.2 Dedicated downlink physical channels .................................................................................................. 21
5.3.2.1 STTD for DPCH and F-DPCH......................................................................................................... 25
5.3.2.2 Dedicated channel pilots with closed loop mode transmit diversity ................................................... 26
5.3.2.3 Void ................................................................................................................................................ 27
5.3.2.4 E-DCH Relative Grant Channel ....................................................................................................... 27
5.3.2.5 E-DCH Hybrid ARQ Indicator Channel ........................................................................................... 29
5.3.2.6 Fractional Dedicated Physical Channel (F-DPCH) ........................................................................... 29
5.3.3 Common downlink physical channels.................................................................................................... 30
5.3.3.1 Common Pilot Channel (CPICH) ..................................................................................................... 30
5.3.3.1.1 Primary Common Pilot Channel (P-CPICH) ............................................................................... 31
5.3.3.1.2 Secondary Common Pilot Channel (S-CPICH) ........................................................................... 31
5.3.3.2 Downlink phase reference................................................................................................................ 32
5.3.3.3 Primary Common Control Physical Channel (P-CCPCH) ................................................................. 33
5.3.3.3.1 Primary CCPCH structure with STTD encoding ......................................................................... 34
5.3.3.4 Secondary Common Control Physical Channel (S-CCPCH) ............................................................. 34
5.3.3.4.1 Secondary CCPCH structure with STTD encoding ..................................................................... 37
5.3.3.5 Synchronisation Channel (SCH) ...................................................................................................... 37
5.3.3.5.1 SCH transmitted by TSTD ......................................................................................................... 38
5.3.3.6 Void ................................................................................................................................................ 38
5.3.3.7 Acquisition Indicator Channel (AICH) ............................................................................................. 38
5.3.3.8 Void ................................................................................................................................................ 42
5.3.3.9 Void ................................................................................................................................................ 42
5.3.3.10 Paging Indicator Channel (PICH) .................................................................................................... 42
5.3.3.11 Void ................................................................................................................................................ 43
5.3.3.12 Shared Control Channel (HS-SCCH) ............................................................................................... 43
5.3.3.13 High Speed Physical Downlink Shared Channel (HS-PDSCH) ......................................................... 43
5.3.3.14 E–DCH Absolute Grant Channel (E-AGCH).................................................................................... 44
5.3.3.15 MBMS Indicator Channel (MICH) .................................................................................................. 44
6 Mapping and association of physical channels ................................................................................... 45
6.1 Mapping of transport channels onto physical channels ................................................................................ 45
6.2 Association of physical channels and physical signals ................................................................................. 46
7 Timing relationship between physical channels ................................................................................. 47
7.1 General ...................................................................................................................................................... 47
7.2 PICH/S-CCPCH timing relation ................................................................................................................. 48
7.2A PICH/HS-SCCH timing relation ................................................................................................................. 48
7.3 PRACH/AICH timing relation .................................................................................................................... 49
7.3A UL/DL timing relation for Enhanced Uplink in CELL_FACH state and IDLE mode ................................... 50
7.4 Void .......................................................................................................................................................... 51
7.5 Void .......................................................................................................................................................... 51
7.6 DPCCH/DPDCH timing relations ............................................................................................................... 51
7.6.1 Uplink .................................................................................................................................................. 51
7.6.2 Downlink ............................................................................................................................................. 51
7.6.3 Uplink/downlink timing at UE .............................................................................................................. 51
7.7 Uplink DPCCH/HS-DPCCH/HS-PDSCH timing at the UE ......................................................................... 51
7.8 HS-SCCH/HS-PDSCH timing .................................................................................................................... 52
7.9 MICH/S-CCPCH timing relation ................................................................................................................ 52
7.10 E-HICH/P-CCPCH/DPCH timing relation .................................................................................................. 53
7.11 E-RGCH/P-CCPCH/DPCH timing relation................................................................................................. 53
7.12 E-AGCH/P-CCPCH timing relation............................................................................................................ 54
7.13 E-DPDCH/E-DPCCH/DPCCH timing relation ........................................................................................... 54
25211-910.pdf
2.58 MB, 下载次数: 33 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-11-9 08:06:15 | 显示全部楼层
good standard referenc e
发表于 2010-12-4 13:52:24 | 显示全部楼层
没有错啊
发表于 2011-6-12 21:23:11 | 显示全部楼层
ding yi xia
GMT+8, 2025-12-19 15:09 , Processed in 0.021278 second(s), 7 queries , Gzip On, Redis On.
