查看: 2692|回复: 0
[资料] 供应1553B配件耦盒器 1553B板卡
发表于 2010-11-3 16:49:43 | 显示全部楼层 |阅读模式
美国EXC 1553b 标准连接组件
1553b专用电缆:M17-176-00002 双绞屏蔽线
PL75-47 适用于M17-176-00002电缆的接头
CJ70-47 适用于M17-176-00002电缆的接头()
BJ77 穿舱插座,与PL75-47匹配
BJ76BJ76FL穿舱,防水插座
配套的连接器:PL75C-219PL75CFL-219
总线耦合器:
单子线耦合器 ESI-110
双子线耦合器 ESI-210
三子线耦合器 ESI-310
四子线耦合器 ESI-410
五子线耦合器 ESI-510
八子线耦合器 ESI-810
型号 连接器(CONNECTOR 匹配连接器
ESI-110 BJ770 (MINATURE) PL75-47
ESI-111 BJ770 (MINATURE) ONE INTERNALTERMINATION PL75
ESI-120 BJ377 (MINATURE THREADED) PL375
ESI-130 BJ157 (SUB-MINATURE) PL155
ESI-140 BJ3157 (SUB-MINATURE THREADEDPL3155
PART NUMBER CONNECTOR MATING CONNECTOR
ESI-210 BJ770 (MINATURE) PL75
ESI-211 BJ770 (MINATURE)ONE INTERNALTERMINATION PL75
ESI-220 BJ377 (MINATURE THREADED) PL375
ESI-230 BJ157 (SUB-MINATURE) PL155
ESI-240 BJ3157 (SUB-MINATURE THREADEDPL3155
1553b各种连接器:
ESI-PL75-47 PL75-47 for M17/176-00002 Cable
ESI-PL75-49 PL75-49 for TWC-78-1F2 Cable
ESI-PL155-47 PL155-47 for M17/176-00002Cable
Cable Plug P/N: PL75Cable Jack P/N: CJ70Plug-to-Plug Adapter P/N: AD78Bulkhead Jack P/N: BJ770
Bulkhead Jack P/N: BJ76Bulkhead Cable Jack P/N: BJ79Cable Plug (slide-on) P/N: PL73Tee P/N: BN73
Cable Jack (threaded) P/N: CJ370Cable Plug P/N: PL375Dust Cap P/N: RT50000
Dust Cap w/o Chain P/N: RT50000ncBulkhead Jack P/N:BJ157Cable Plug P/NL3155 (threaded)
Cable Jack P/N: CJ150#8 Contact P/N:8-90 (male)8-91(female)Terminator(78ohms) P/N: RT500078
Terminator (78 ohms) P/N: RT600078Terminator (78 ohms) P/N: RT700078Terminator (78 ohms) P/N: RT800078
瑞侃系列:
DK-621主要是为MIL-STD-1553B数据总线设计的,具有高可靠性、耐用性。
特点:
1)满足MIL-STD-1553B的硬件要求
2)可拆型插针和插孔
3)与1553B数据总线电缆相匹配
4360度的连续屏蔽,结构坚固
5)应力释放,低电压降和高可靠性
6)螺口与卡口两种方式,安装简便
71000小时防烟雾
1瑞侃raychem 1553B总线连接器|耦合器产品:
DK-621, D-500, D-621, D-602系列连接器,D-602-0141DK-621-1412-SDK-621-1412-PDK-621-1411-S
DK-621-1411-PDK-621-0440-4SDK-621-0440-4PDK-621-0439-4P
DK-621-0011PDK-621-0012SDK-621-0433-1PDK-621-0434-1S
DK-621-0433-1P DK-621-0433-1SDK-621-0434-1PD500-0255-023D500-0255-022D-500-0465-1-612-078D-500-0455-2-612-012 55A0111-14-955A0111-16-955A0111-18-955A4121-18-2/96-955A0111-20-955A0111-22-955A1111-22-9-955A1131-22-2/93/96-9PLR75C-204PLR75CFL-20455A0111-21-955A4121-24-9/96-955A1121-24-9/96-982A1121-24-9/96-955A4131-24-9/96/9-982A4131-24-9/93/96-955A1131-24-9/93/96-9 TMS-SCE-3/32-2.0-S2-9,
TMS-SCE-1/8-2.0-S2-9, TMS-SCE-1/2-2.0-S2-9,
TMS-SCE-1-2.0-4, TMS-SCE-1-1/2-2.0-4 ,
TMS-SCE-2-2.0-4, TMS-101-RIBBON-4PRSCE,
HT-SCE-1/8-2.0-9,
HT-SCE-3/16-2.0-9 APKT-10C1X1-H3,
APKT-10D1X1-H3,
APKT-10B1X1-H3, APKT-10D1X0-H3,
APKJ-10C1X4-1X4 DB40010RT500078CJ70-XXD-621-0435
D-500-0455-2-612-078 D-500-0455-1-612-078D-500-0456-1-613-078
D-500-0457-1-613-078 DK-621-0411-SDK-621-0411-P DK-621-0412-P DK-621-0412-S
DK-621-0440-4P DK-621-0440-4S DK-621-0439-4PDK-621-0439-4S DK-621-0433-1S
DK-621-0433-1P D-621-0423 D-621-0424D-621-0406 D-621-0456 D-621-0472 D-621-0469
D-150-9133 D-500-0463-612 D-100-00D-500-0463-612 D-150-9708-5
D-500-0455-1-612-012 D-150-0124 D-602-0140D-602-0146 D-602-0141 D-602-0147
2瑞侃raychem热缩套管|模缩套|标识套:
202A132-3-0 202K132-3-0 382A023-3-0301A514-71-0 382A023-3-0 DR-25-3/16-0-SP
HCTE-0281-0-SP DR-25-TW-1-0-SPTMS-SCE-3/16-2.0-9 TMS-SCE-3/8-2.0-9
TMS-SCE-3/4-2.0-9 TMS-SCE-1/4-2.0-9RNF-100-1/2-BK/SP RNF-100-1/4-BK/SP
RNF-100-3/16-BK-SP RNF-100-1/16-BK-SPRNF-100-1/8-BK-SP DR-25-1/2-0-SP
DR-25-TW-3/8-0-SP DR-25-1/8-0-SPTMS-SCE-1/8-2.0-4 TMS-SCE-1-2.0-4
TMS-SCE-1-2.0-9 TMS-SCE-1-1/2-2.0-4TMS-SCE-1/8-2.0-4 TMS-SCE-1-2.0-4
TMS-SCE-1-1/2-2.0-4 TMS-SCE-1/2-2.0-4TMS-SCE-3/4-2.0-4 HCTE-0281-0-SP
TMS-101-RIBBON-4RPSCE ATUM-32/8-0-STKRT-375-1/4-X-SP RT-375-3/8-X-SP
VITON-1/2-0-SP VITON-1/4-0-SPVITON-1/8-0-SP VITON-3/8-0-SP VITON-3/16-0-SP
VITON-1-0-SP TMS-101-RIBBON-4HTVERSAFIT-1/8-0-SP VERSAFIT-3/4-0-SP
VERSAFIT-3/8-0-SP VERSAFIT-3/16-0-SPVERSAFIT-1-0-SP VERSAFIT-1-1/2-0-SP
DR-25-1/2-0-SP DR-25-1/4-0-SPDR-25-1/8-0-SP HT-SCE-1/8-2.0-9 TMS-SCE-1/4-2.0-9
TMS-SCE-1/2-2.0-9 RMK6-WM-9 ATUM-19/6-0-STKR-25-TW-1/8-0-SP 222K142-3-0
222K152-3-0 382C302-71-0 202F221-71-0202F242-71-0 202F253-71-0 RT-375-1/4-X-SP
RT-375-1/-X-SP RT-375-1/2-X-SPATUM-3/8-0-STK
3、瑞侃RAYCHEM电线电缆及附件:
5024A3314-0 5026A1314-9 55A0111-14-955A0111-18-9 55A0111-20-9 55A0111-22-0
55A0111-22-2 55A0111-22-9 55A0111-24-055A0111-24-9 55A0111-26-1 55A0111-26-2
55A0111-26-5 55A0112-24-9 55A0811-10-955A0811-12-9 55A0811-14-9 55A0811-16-9
55A0811-18-9 55A0811-20-9 55A0811-22-255A0811-22-9 55A0811-4-9 55A0814-26-9
55A0814-26-9 55A1111-12-9-9 55A1111-14-9-955A1111-16-9-9 55A1111-22-9-9
55A1121-22-6/9-9 55FA0511-16-7 55A0112-18-955A0112-18-2 55A0112-22-9
55A0112-22-6 55A1111-22-9-9 55A0811-22-955A1111-12-9-9 55A1111-18-9-9
55A1111-20-9-9 55A0811-10-9 55A0812-10-955A1111-20-9-9 55A1111-22-9-9
5A0811-18-9 5A0812-12-9 55A0812-18-955A0812-20-9 55A1112-12-9-9
55A1132-20-3/6/9-9 55A1111-10-9-955A1111-18-9-9 55A0811-6-9 55A0811-16-9
55A1111-16-9-9 55A1122-22-6/9-9 5A0811-20-95A1112-22-9-9 D-436-36 D-436-37
D-436-38 SO63-3-00 SO63-4-00SO63-4-55-22-90 SO63-3-55-20-90 SO63-2-55-22-90
SO63-3-55-20-90 SO63-3-55-22-90D-500-0458-1-612-078 SO63-3-00 TXR40AB00-2420AI
D-406-0001 D-406-0003 D-436-52 D-436-53D-436-82 D-436-83 D-436-85 D-436-86
D-436-87 D-436-88 D-150-9708-5 SO63-3-01
1553B全系列配件
1553B配件
(1) 无链终端匹配器
产品号
功能
接口类型
阻值
10-06403-033
总线端接电阻
三同轴三爪公
78 ohm 2W 1%
10-06403-033
总线端接电阻
三同轴三爪公
78 ohm 2W 1%
10-06403-033
设备端接电阻
三同轴三爪公
1000 ohm 2W 1%
10-06403-033
设备端接电阻
三同轴三爪公
2000 ohm 2W 1%
10-06403-033
设备端接电阻
三同轴三爪公
3000 ohm 2W 1%
(2) 终端匹配器带6寸链
功能
接口类型
阻值
总线端接电阻
三同轴三爪公
78 ohm 2W 1%
总线端接电阻
三同轴三爪公
78 ohm 2W 1%
设备端接电阻
三同轴三爪公
1000 ohm 2W 1%
设备端接电阻
三同轴三爪公
2000 ohm 2W 1%
设备端接电阻
三同轴三爪公
3000 ohm 2W 1%
3RFI 防尘帽
功能
接口类型
hain Option
保护耦合器上的插座
三同轴三爪公
none
保护耦合器上的插座
三同轴三爪公
6 inch brass
4)转接器
Description
接口类型
Barrel
三同轴三爪母 to
Tee
三同轴三爪公 to two 三爪母s
弯角
三同轴三爪公 to 三爪母
5)线缆连接工具
产品号
描述
10-06950
M17/176-00002线缆焊接工具 (8 件套)
40-40451
HG-3002LCD Heat Gun With Temp Output and Case
AD-1377
ConductorCrimp Too
1553B总线切换开关
1553B总线开关系列产品主要是被用来在MIL-STD 1553总线的A通道和冗余总线B通之间切换。切换时并不中断总线通讯。DBPR2000 系列产品能够将一个应用终端从一个总线切换到另一个总线上(经常是从总线A切换到冗余总线B上)。 它能够同时切换4个总线。 本产品还经常被用作将一个网络分解成一些独立的部分。如果你想在网络上加入MIL-STD 1760 存储管理设备, 总线开关将会非常有用。
系统中应用总线切换开关带来的好处:
*总线切换开关可以通过5V或者28V电压信号远程控制。
*可以迅速关断总线或者切换总线。
方便切入切出数据采集终端和总线监视器。
联系人:刘小姐
电话:029882483398064
手机:13619203763
Emailliuzhimiao@fy-ic.com
MSNfangyuanming2972@hotmail.com
地址:西安市西高新开发区科技路10号华奥大厦C24
公司网站:www.1553-cpci.com
GMT+8, 2025-12-21 12:30 , Processed in 0.012522 second(s), 4 queries , Gzip On, Redis On.
