查看: 6361|回复: 13
[求助] CTS求助
发表于 2010-10-14 13:54:19 | 显示全部楼层 |阅读模式
一直对某些概念没搞明白,不知道CTS里leaf_pin,sink_pin,excluded_pin,through_pin,
以及global_leaf_pin,global_sink_pin,global_excluded_pin,global_through_pin,global_preserve_pin是什么意思?什么情况下会设置?
请高手指点下
发表于 2010-10-14 16:51:55 | 显示全部楼层
good question , I also confused at it.  wait for expert ???
发表于 2010-10-14 18:54:29 | 显示全部楼层
看看encounter的user guide不久明白了吗?
 楼主| 发表于 2010-10-14 19:49:15 | 显示全部楼层
发表于 2010-10-15 17:33:50 | 显示全部楼层
里面肯定会讲滴,,,,仔细找
发表于 2010-10-16 17:01:54 | 显示全部楼层
Please refer to:
Encounter User Guide,
chapter 16: Synthesizing Clock Trees,
section: Understanding CTS Operation Modes
All these commnads add or remove some pins from clock pins set.
To understand these terms, lets see how clock pins are recognized (I've copied these from the manual):
Automatic CTS for Gated Clocks
For automatic-gated CTS, CTS traces the clock tree starting from a root pin. The tracing
begins at the root pin, then continues through the buffers, inverters, multi-output cells, and
gated instances to establish the clock tree. The tracing stops at
- A clock pin
- An asynchronous set/reset pin
- An input pin without any timing arc to an output pin
- A user-specified leaf pin or excluded pin
- Data pin of registers (or flops)
- Asynchronous set or reset pin of registers (or flops)
- Enable pins of tri-state instances
After the tracing, CTS builds the clock buffer tree topology to balance the clock phase delay
with inserted clock buffers.
So:
leafPin:
If we want to force cts to stop at a special pin that is not a clock pin ( for any reason ) and
synchronize this pin with other clock pins, we use leafpin command.
excludedPin:
If we want to force cts to stop at a special pin that is a clock pin or a pin that tracing through it will end up at some clock pins, we use excludedpin command. So the affected pins will not be synchronized with other clock pins.
throughPin:
If we want to force cts to continue tracing through a special pin (that it normally treat the pin as clock pin), we use throughPin command. For example, if we have devided the clock by a DFF, then the D-pin of DFF should be in throughPin list, and the nets that are drived by Q- or QN-pins will act as clocks. Else cts will stop at clock pin of dividing DFF, and the drived clocks will not synchronous.
 楼主| 发表于 2010-10-18 09:53:07 | 显示全部楼层
回复 6# smn1380
谢谢楼上的
发表于 2010-10-18 22:13:01 | 显示全部楼层
不错,不错。
发表于 2012-2-6 16:25:40 | 显示全部楼层
看不到答案阿
发表于 2012-2-6 17:09:03 | 显示全部楼层
为什么被屏蔽了,好想看看有什么新东西
GMT+8, 2025-12-25 13:13 , Processed in 0.022982 second(s), 6 queries , Gzip On, Redis On.
