查看: 10938|回复: 33
[招聘] [猎头招聘] 美资知名IC公司招聘 设计/验证工程师 (工作地点:成都)
发表于 2010-10-9 12:39:57 | 显示全部楼层 |阅读模式
以下两个职位分别是设计验证工程师和验证工程师,工作地点是成都。
请有兴趣的朋友和我联系,简历发送到我的邮箱里,谢谢。
harryhahn@hotmail.com
•Job Description
Position title: SoC ASIC Design/Verification Engineer
Responsibilities:
o Integration of ARM processor/DSP co-processor and AMBA bus for SoC;
o Integration of H264 Codec , DDR, USB and PCIe etc for SoC;
o Design/verification of  video surveillance and audio & voice processor with integrated CODEC and amplifier
o Design SoC-level logic including clock, reset, and DFT;
o Verification of AMBA-based DMA, Memory Subsystem, and all peripheral interfaces at unit level and SoC level
o Work with analog group and physical layout team on analog macro integration and synthesis/timing analysis.
Qualification:
o 5+ years experience on SoC  design and integration;
o Hand-on experience in ASIC flow;
o Experience of ARM/DSP/AMBA integration and/or verification;
o Experience of DMA design and/or verification;
o Experience of H264 Codec & DDR SoC integration and verification
o Experience of video surveillance project design and verification
o Experience of design/verification for audio & voice processor with integrated Codec and amplifiers is a big plus
o Domain knowledge on Nand Flash Controller, USB, and PCIe is a plus
o DFT (Memory BIST and scan) design background is a plus
• Job Description
Position title: SoC ASIC Verification Engineer
Responsibilities:
o Instrumental in the development of infrastructure for the validation of ARM/DSP AMBA-based architectures and the verification of SoC hardware.
o Additional duties include the development of directed and random hardware verification environments, and the application of those environments to SOC verification
o Integration of VIP UVC and functional verification agents in OVM/UVM verification environment to support  coverage-driven verification
Qualification:
o Extensive Verilog experience with SOC verification environments.
o  Verification experience on ARM/DSP, AXI, and DMA with VIP UVC
o Experience developing bus functional models, monitors, scoreboards, generators, functional coverage models
o Experience with high level verification languages such as SystemVerilog, OVM or VMM, Vera or Specman, and strong C++ programming background
o Shell scripts and Perl expertise, create runsim, lsf, regression management scripts
o Able to understand Verilog RTL code, debug simulation errors, identify and fix RTL/Environment issues
 楼主| 发表于 2010-10-9 15:01:14 | 显示全部楼层
up up
 楼主| 发表于 2010-10-9 23:21:09 | 显示全部楼层
up up
 楼主| 发表于 2010-10-10 11:39:10 | 显示全部楼层
up up
发表于 2010-10-10 15:02:05 | 显示全部楼层
看看怎么样
 楼主| 发表于 2010-10-10 18:09:07 | 显示全部楼层
up up
 楼主| 发表于 2010-10-11 09:45:37 | 显示全部楼层
up up!
 楼主| 发表于 2010-10-12 19:49:47 | 显示全部楼层
up up~~
 楼主| 发表于 2010-10-13 13:02:47 | 显示全部楼层
up up
 楼主| 发表于 2010-10-14 10:27:19 | 显示全部楼层
up up~~
GMT+8, 2025-9-14 03:02 , Processed in 0.019935 second(s), 3 queries , Gzip On, Redis On.
