查看: 4291|回复: 8
[资料] A 10-bit 50-MS/s Pipelined ADC With Opamp Current Reuse
发表于 2010-10-2 21:20:59 | 显示全部楼层 |阅读模式
Power and area saving concepts such as operational
amplifier (opamp) bias current reuse and capacitive level
shifting are used to lower the analog power of a 10-bit pipelined
analog-to-digital converter (ADC) to 220 W/MHz. Since a
dual-input bias current reusing opamp performs as two opamps,
the opamp summing nodes can be reset in every clock cycle. By
using only N-channel MOS (NMOS) input stages, the capacitive
level shifter simplifies the gain-boosting amplifier design and
enables fast opamp settling with low power-consumption. The
prototype achieves 9.2/8.8 effective number of bits (ENOB) for
1- and 20-MHz inputs at 50 MS/s. The ADC works within the
temperature range of 0 to 85 C and the supply voltage from
1.62 to 1.96 V with little measured loss in the ENOB. The chip
consumes 18 mW (11 mW for the analog portion of the ADC and
7 mW for the rest including buffers) at 1.8 V, and the active area
occupies 1 1 1 3 mm2 using a 0.18- m complementary metal
oxide semiconductor (CMOS) process.
2.pdf
1.23 MB, 下载次数: 90 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-10-2 22:56:21 | 显示全部楼层
thanks for sharing
发表于 2014-6-29 19:16:01 | 显示全部楼层
op current !
发表于 2015-4-16 09:36:18 | 显示全部楼层
感谢楼主分享
发表于 2015-4-16 21:53:49 | 显示全部楼层
路过路过
发表于 2015-4-22 15:00:45 | 显示全部楼层
路过帮顶
发表于 2016-5-5 16:05:34 | 显示全部楼层
回复 1# vensen
   这个不错,多谢LZ的分享~~~
发表于 2016-7-21 18:15:49 | 显示全部楼层
THANK YOU
发表于 2016-11-30 10:54:12 | 显示全部楼层
thanks for sharing
GMT+8, 2025-12-26 04:31 , Processed in 0.024320 second(s), 7 queries , Gzip On, Redis On.
