查看: 7146|回复: 5
National Instruments Multisim & Ultiboard PowerPro 11.0 | 401 MB
发表于 2010-10-1 22:47:49 | 显示全部楼层 |阅读模式
Multisim equips educators, students, and professionals with the tools to analyze circuit behavior. The intuitive and easy-to-use software platform combines schematic capture and industry-standard SPICE simulation into a single integrated environment. Multisim abstracts the complexities and difficulties of traditional syntax-based simulation, so you no longer need to be an expert in SPICE to simulate and analyze circuits. Multisim is available in two distinct versions to meet the teaching needs of educators or the design needs of professionals.
Ultiboard provides an easy and intuitive platform to design printed circuit boards (PCBs). The flexible Ultiboard design environment offers automated functionality for speed and manual techniques for precise control. With complete integration to NI Multisim, Ultiboard helps you optimize PCB design. Quickly prototype whether for professional designs or academic research.
Download
http://hotfile.com/dl/24123657/27a0c2d/NI.Multisim.Power.Pro.11.part1.rar.html
http://hotfile.com/dl/24123690/eec89dd/NI.Multisim.Power.Pro.11.part2.rar.html
http://hotfile.com/dl/24123713/3596948/NI.Multisim.Power.Pro.11.part3.rar.html
http://hotfile.com/dl/24122498/d700584/NI.Multisim.Power.Pro.11.part4.rar.html
http://hotfile.com/dl/24123716/7ea6a5d/NI.Multisim.Power.Pro.11.part5.rar.html
http://www.filefactory.com/file/a1918ag/n/NI.Multisim.Power.Pro.11.part1.rar
http://www.filefactory.com/file/a191781/n/NI.Multisim.Power.Pro.11.part2.rar
http://www.filefactory.com/file/a19178a/n/NI.Multisim.Power.Pro.11.part3.rar
http://www.filefactory.com/file/a191775/n/NI.Multisim.Power.Pro.11.part4.rar
http://www.filefactory.com/file/a19177h/n/NI.Multisim.Power.Pro.11.part5.rar
http://rapidshare.com/files/335146502/NI.Multisim.Power.Pro.11.part5.rar.html
http://rapidshare.com/files/335147291/NI.Multisim.Power.Pro.11.part4.rar.html
http://rapidshare.com/files/335147533/NI.Multisim.Power.Pro.11.part3.rar.html
http://rapidshare.com/files/335147361/NI.Multisim.Power.Pro.11.part2.rar.html
http://rapidshare.com/files/335147377/NI.Multisim.Power.Pro.11.part1.rar.html
Note:
1. Run the generator licenses KeyGen_unpack_v110000.exe which is located in the folder "KG_v110000".
2. From the open window to overwrite the serial number.
3. Press "1" (this corresponds to the choice of versions of Power Pro).
4. Press Enter. At the same time in the same folder that contains the generator, there will be 2 files license.
5. Run the installation program and when prompted enter serial number, enter the serial number copied.
6. After the installation is to abandon reboot.
7. Open the folder "C: \ Program Files \ National Instruments \ Shared \ License Manager \ Licenses" and copy it obtained a license.
8. Start License Manager ( "C: \ Program Files \ National Instruments \ Shared \ License Manager \ Bin \ nilmUtil.exe"), in a new window
select the line Multisim 11.
9. Press the button F8, and then open the folder "Licenses".
10. In the opened folder "Licenses" select the license file (need to click on the desired file), in this case, the license file for
Multisim 11 Power Pro (the one that copied see paragraph 7), in the opened window click Yes. Then check mark next to Power Pro Edition
should light up green (see the attached skin Licenses.jpg).
11. The same should be done to Ultiboard 11. (Do not confuse the license. They are different. For each program has its own!).
12. Reboot the computer.
Good Luck!!
发表于 2011-6-28 02:40:43 | 显示全部楼层
Thanks a lot.
发表于 2011-8-18 20:12:01 | 显示全部楼层
Thanks a lot.
发表于 2012-3-30 09:36:56 | 显示全部楼层
谢谢楼主,还不知道可以。重启一下试试。
发表于 2014-5-8 02:07:48 | 显示全部楼层
谢谢你的分享!
发表于 2016-1-6 22:42:39 | 显示全部楼层
都过期了,可以重新分享吗
GMT+8, 2025-12-23 05:48 , Processed in 0.020139 second(s), 5 queries , Gzip On, Redis On.
