楼主: gman
FEKO v6.0::crack
发表于 2010-11-6 15:41:05 | 显示全部楼层
发表于 2010-11-6 22:34:21 | 显示全部楼层
这个论坛里提到如何破解了
发表于 2010-11-7 00:10:42 | 显示全部楼层
 楼主| 发表于 2010-11-7 02:01:15 | 显示全部楼层
Dear Yuncee,
this is wat russian hackers says:............................................................................................................................
after the installation of FEKO 6.0,
if you have not installed the system FEKO 5.5,
by regedit'a export the registry branch
HKLM \ SOFTWARE \ FEKO \ 6.0, open the resulting reg-file notepad
and change the name of the branch for 32-bit Windows as follows:
[HKEY_LOCAL_MACHINE \ SOFTWARE \ FEKO \ 6.0] -> [HKEY_LOCAL_MACHINE \ SOFTWARE \ FEKO \ 5.5]
[HKEY_LOCAL_MACHINE \ SOFTWARE \ FEKO \ 6.0 \ Environment] ->
-> [HKEY_LOCAL_MACHINE \ SOFTWARE \ FEKO \ 5.5 \ Environment]
and 64-bit like this:
[HKEY_LOCAL_MACHINE \ SOFTWARE \ FEKO \ 6.0] -> [HKEY_LOCAL_MACHINE \ SOFTWARE \ Wow6432Node \ FEKO \ 5.5]
-> [HKEY_LOCAL_MACHINE \ SOFTWARE \ Wow6432Node \ FEKO \ 5.5 \ Environment]
imortiruyte saved reg-file into the registry (double-click on the file name).
save the original secfeko.exe, replace it proposed in the archive.
open the file proposed secfeko.dat notepad
run the License Manager, copy in the window
Your machine_code in secfeko.dat instead 000000000000, save the file,
After saving a file can be closed in the License Manager'e window "error."
Click the Update button in the License Manager'e, copy
Good Password first in your secfeko.dat, save it,
copy in the second secfeko.dat Good Password, save it.
Click the Update button in the License Manager'e again
and verify the validity of your license.
Now you can restore the original secfeko.exe,
and work with the program.
feko6fix2(2).rar
214.38 KB, 下载次数: 910 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-11-7 02:02:49 | 显示全部楼层
please dont do any request like that....thanks
发表于 2010-11-7 10:29:46 | 显示全部楼层
看看好不好用,先谢谢了。
发表于 2010-11-7 15:41:44 | 显示全部楼层
回复 64# gman
It works, thanks a lot. I downloaded the fix from their ftp, and tried just now, it worked.
Thanks all the same, thanks for sharing the fix.
发表于 2010-11-9 14:07:45 | 显示全部楼层
回复 67# yuncee
    请问您在哪里下载的fix,我非常想安装一下feko6.0,能否向您求借一下?非常感谢您!
发表于 2010-11-9 15:19:48 | 显示全部楼层
回复 62# yuncee
    那个网站全是俄文的,看不懂啊!能否求教您如何破解啊?急求!!!
发表于 2010-11-9 16:45:20 | 显示全部楼层
回复 15# gman
您好!
可否请您用中文表达一下安装方法?我安装了很多遍装完之后都没法计算,请求您描述的清楚一下,本人实在是理解力不行。
GMT+8, 2025-12-10 10:22 , Processed in 0.019756 second(s), 5 queries , Gzip On, Redis On.
