楼主: gman
FEKO v6.0::crack
发表于 2010-10-18 21:13:56 | 显示全部楼层
谢谢........................
发表于 2010-10-18 23:17:15 | 显示全部楼层
Not Working... either with x32 and x64 bit version.
All seems to be fine with license, but when you try any simulation there were the "segmentation violation" error :
Calculation of the elements of MoM submatrices
FEKO caught signal 11
Segmentation violation
ERROR 3978: Internal FEKO error. Please notify the FEKO support team and provide the error number, preferably together with the FEKO input and output files.
Anybody know a real solution or have tried to use the solver simulator after fix it ??
Best Regards
发表于 2010-10-18 23:25:14 | 显示全部楼层
thanks
发表于 2010-10-19 00:00:42 | 显示全部楼层
Reply 1 # gman
    Thanks a lot.
 楼主| 发表于 2010-10-19 01:49:07 | 显示全部楼层
dear pippopo,
check ur windows as there is no virus. reinstall it for better operation.
发表于 2010-10-19 02:17:01 | 显示全部楼层
谢谢
我会尝试
发表于 2010-10-19 02:58:34 | 显示全部楼层
Hi, everybody,I post my machine code
          mach_code_01 of type 12: "HPQZFLRFIDPMHZUR"
          mach_code_02 of type 11: "HPQZFLRFIDPMHZUR"
          mach_code_03 of type  6: "00241D8E24B3"
          mach_code_04 of type 10: "38402F392D33232E"
          mach_code_05 of type  8: "8C5B9B5C"
          mach_code_06 of type  1: "4540484C213232383133"
          mach_code_07 of type 99: "D601D90E78AC2CDA2107F56EA02A9352"
can you calculate a key for me??
It's always show a error for me, I do not known y:
ERROR  9016:
  Good  password
    "NAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA"
  in line 4 of the licence file for the machine code
发表于 2010-10-19 04:08:19 | 显示全部楼层
gman, i have tried with 5 pc, reformatting too. the secfeko u have posted is for a old version.
The same results of this can be obtained using the feko 5.5 crack. The license manager wil be fine, like this fix, but then when u open feko and u open a example project and try to sinulate the feko.exe solver will be puntually report the error i had posted.
There is anyone that after applied the fix, have launch one simulation and then see the results with postfeko ?? this is  the point.
One license accepted is not the same that a running software.
I have tried 5 machines and the fix is not working.  The new version of feko (6) have 3 password into the license file, the file posted here (old version) have only 2 password, so this is a negative point for the fix to work.
Someone can confirm this things ??
Best Regard
发表于 2010-10-19 05:21:39 | 显示全部楼层
回复 38# pippopo
发表于 2010-10-19 06:01:55 | 显示全部楼层
ok mosika. That screen is what i mean. The same screen is what i see every time i try any project simulation.
The fix isn't working.But this is normal, the fix is working for 5.5 version and not for 6.
Someone can confirm this screen ?? I can confirm it !
Anybody have a real suggestion ??
Best Regards
GMT+8, 2025-12-10 10:22 , Processed in 0.183630 second(s), 6 queries , Gzip On, Redis On.
