楼主: gman
FEKO v6.0::crack
 楼主| 发表于 2010-10-4 11:56:46 | 显示全部楼层
use cmd window for secfeko.exe...or explain what wrong is displayed there?
发表于 2010-10-6 13:48:50 | 显示全部楼层
多谢了啊
发表于 2010-10-6 19:57:04 | 显示全部楼层
Thank you for sharing!!!
发表于 2010-10-7 09:56:34 | 显示全部楼层
回复 1# gman
Can you provide an instruction how to install it. I got this error as shown below:
ERROR  9016:
  Wrong password
    "NAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA"
  in line 4 of the licence file for the machine code
    "00000000000".
 楼主| 发表于 2010-10-10 20:13:18 | 显示全部楼层
1) install FEKO Suite 6.0
2) backup your original \FEKO\License\secfeko.dat (if any) and \FEKO\bin\secfeko.exe
3) unrar provided archive to \FEKO folder, your secfeko.exe and secfeko.dat should be overwritten
4) open \FEKO\License\secfeko.dat with notepad for editing
5) run Start->Programs->FEKO->Suite 6.0->License manager (Suite 6.0), SECFEKO Error window will appear
6) select with mouse and copy to clipboard some Machine code from SEKFEKO Error window (without quotes), don't close this window
7) go to notepad and replace 000000000000 with your Machine code, save secfeko.dat
8) close SEKFEKO Error window and click "Update" button in License manager window, SECFEKO Error window will appear
9) select with mouse and copy to clipboard Good password (without quotes) from SEKFEKO Error window
10) go to notepad and replace your 1st password with password copied, save secfeko.dat
11) close SEKFEKO Error window and click "Update" button in License manager window, SECFEKO Error window will appear again
12) select with mouse and copy to clipboard Good password (without quotes) from SEKFEKO Error window
10) go to notepad and replace your 2nd password with password copied, save secfeko.dat, close notepad
13) close SEKFEKO Error window and click "Update" button in License manager window, check out all available Components and Modules
14) close License Manager window, run FEKO and work!
PS. you can restore original file secfeko.exe now, the program will continue to work.
发表于 2010-10-15 09:27:25 | 显示全部楼层
回复 15# gman
gman,
Thank you very much for the installing instruction.  I will give it a try.
发表于 2010-10-15 09:57:13 | 显示全部楼层
可以用于 64 位的 feko 么??
发表于 2010-10-15 10:02:41 | 显示全部楼层
提示
Error  20064:
  Error opening the registry key "HKLM\SOFTWARE\FEKO\5.5\Environment".
该怎么处理??
发表于 2010-10-15 13:49:21 | 显示全部楼层
不能用 这个方法   可以启动  但是不能计算案例  请楼主帮忙
发表于 2010-10-15 14:29:45 | 显示全部楼层
xiexie
GMT+8, 2025-12-10 10:22 , Processed in 0.017876 second(s), 4 queries , Gzip On, Redis On.
