查看: 5279|回复: 20
[资料] 关于FPGA流水线设计论文(IEEE)
发表于 2010-9-17 18:44:54 | 显示全部楼层 |阅读模式
关于FPGA流水线设计论文(IEEE)
关于FPGA流水线设计论文(IEEE).pdf
216.5 KB, 下载次数: 160 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-9-17 21:45:48 | 显示全部楼层
看看,学习一下
发表于 2010-11-9 10:44:35 | 显示全部楼层
谢谢分享!
发表于 2010-11-9 13:16:07 | 显示全部楼层
Thanks.
发表于 2010-11-11 23:32:09 | 显示全部楼层
楼主能不能详细说明下?
发表于 2010-11-11 23:33:40 | 显示全部楼层
Design of Very Deep Pipelined Multipliers for FPGAs
Abstract
This work investigates the use of very deep pipelines for
implementing circuits in FPGAs, where each pipeline
stage is limited to a single FPGA logic element (LE). The
architecture and VHDL design of a parameterized integer
array multiplier is presented and also an IEEE 754
compliant 32-bit floating-point multiplier. We show how to
write VHDL cells that implement such approach, and how
the array multiplier architecture was adapted. Synthesis
and simulation were performed for Altera Apex20KE
devices, although the VHDL code should be portable to
other devices. For this family, a 16 bit integer multiplier
achieves a frequency of 266MHz, while the floating point
unit reaches 235MHz, performing 235 MFLOPS in an
FPGA. Additional cells are inserted to synchronize data,
what imposes significant area penalties. This and other
considerations to apply the technique in real designs are
also addressed.
发表于 2010-11-12 23:06:54 | 显示全部楼层
Abstract
also addressed.
发表于 2010-11-13 01:35:39 | 显示全部楼层
ddddddddddd
发表于 2010-11-13 08:20:54 | 显示全部楼层
非常感谢!!!
发表于 2011-4-15 22:20:59 | 显示全部楼层
看看先
GMT+8, 2025-12-23 09:44 , Processed in 0.029607 second(s), 7 queries , Gzip On, Redis On.
