发表于 2012-2-10 11:34:51
显示全部楼层
Quartus® II Introduction for Verilog Users
This tutorial presents an introduction to the Quartus® II software. It gives a general overview of a typical CAD
flow for designing circuits that are implemented by using FPGA devices, and shows how this flow is realized in the
Quartus® II software. The design process is illustrated by giving step-by-step instructions for using the Quartus®
II software to implement a simple circuit in an Altera® FPGA device.
The Quartus® II system includes full support for all of the popular methods of entering a description of the
desired circuit into a CAD system. This tutorial makes use of the Verilog design entry method, in which the
user specifies the desired circuit in the Verilog hardware description language. Another version of this tutorial is
available that uses VHDL hardware description language.
The screen captures in the tutorial were obtained using Quartus® II version 8.1; if other versions of the soft-
ware are used, some of the images may be slightly different. |
