查看: 19496|回复: 5
[求助] DC综合:File is not a DB file. (DB-1)
发表于 2010-8-27 14:03:11 | 显示全部楼层 |阅读模式
各位大侠, 小弟在用DC综合时碰到如下怪象:
1)综合过程顺利通过,基本满足设计要求
2)诸如如下:Error: File is not a DB file. (DB-1)的error不断报出
在下久思未解,敢请坛子中的大侠指点迷津,多谢!
Presto compilation completed successfully.
Current design is now '/iggroup/home/phuang/labs/DC1_2009.06/lab2/rtl/TOP.db:TOP'
Loading db file '/iggroup/home/phuang/labs/DC1_2009.06/lab2'
Error: The file '/iggroup/home/phuang/labs/DC1_2009.06/lab2' is not a DB file.
Loading db file '/CAD/Synopsys/Syn_vC-2009.06-SP4/libraries/syn'
Error: The file '/CAD/Synopsys/Syn_vC-2009.06-SP4/libraries/syn' is not a DB file.
Loading db file '/CAD/Synopsys/Syn_vC-2009.06-SP4/dw/syn_ver'
Error: The file '/CAD/Synopsys/Syn_vC-2009.06-SP4/dw/syn_ver' is not a DB file.
Loading db file '/CAD/Synopsys/Syn_vC-2009.06-SP4/dw/sim_ver'
Error: The file '/CAD/Synopsys/Syn_vC-2009.06-SP4/dw/sim_ver' is not a DB file.
Loading db file '/iggroup/home/phuang/labs/DC1_2009.06/ref/db'
Error: The file '/iggroup/home/phuang/labs/DC1_2009.06/ref/db' is not a DB file.
Loading db file '/iggroup/home/phuang/labs/DC1_2009.06/lab2/scripts'
Error: The file '/iggroup/home/phuang/labs/DC1_2009.06/lab2/scripts' is not a DB file.
Loading db file '/iggroup/home/phuang/labs/DC1_2009.06/lab2/rtl'
发表于 2010-8-27 20:07:08 | 显示全部楼层
文件类型不对吧
发表于 2010-9-14 03:43:30 | 显示全部楼层
db文件時是*.db格式,需要寫出你需要db文件的路徑
发表于 2010-9-14 13:32:26 | 显示全部楼层
check the following env settings are set.
search_path
target_library
link_library
发表于 2015-10-29 08:51:24 | 显示全部楼层
我也碰到了同样的问题!解决办法是将在/home下的工作文件,放置到/usr下即可!
发表于 2023-7-27 20:48:53 | 显示全部楼层
我解决了,原因之前我将db文件复制了一份,但中途使用Ctrl+C打断了,导致文件其实是残缺的,通过查看大小发现的。
遇到该问题的朋友需要检查你的db文件大小是否合理,并找到原先正确地db文件重新复制一份。
GMT+8, 2025-12-24 04:00 , Processed in 0.021549 second(s), 5 queries , Gzip On, Redis On.
