查看: 3767|回复: 2
[求助] quartus9.1 调用synplify201003,为什么没反应。
发表于 2010-8-9 11:45:50 | 显示全部楼层 |阅读模式
原来没用过quartus,没有报错,但是感觉synplify没跑起来,信息如下:
Info: *******************************************************************
Info: Running Quartus II 64-Bit Analysis & Synthesis
    Info: Version 9.1 Build 350 03/24/2010 Service Pack 2 SJ Full Version
    Info: Processing started: Mon Aug  9 11:40:37 2010
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off temp -c temp
Info: Parallel compilation is enabled and will use 8 of the 8 processors detected
Info: Found 1 design units, including 1 entities, in source file temp.v
    Info: Found entity 1: temp
Info: Elaborating entity "temp" for the top level hierarchy
Info: Implemented 2 device resources after synthesis - the final resource count might be different
    Info: Implemented 1 input pins
    Info: Implemented 1 output pins
Info: Quartus II 64-Bit Analysis & Synthesis was successful. 0 errors, 0 warnings
    Info: Peak virtual memory: 252 megabytes
    Info: Processing ended: Mon Aug  9 11:40:38 2010
    Info: Elapsed time: 00:00:01
    Info: Total CPU time (on all processors): 00:00:0
发表于 2011-1-13 12:30:35 | 显示全部楼层
这个还真没有遇到过
不好说
发表于 2011-8-11 20:19:05 | 显示全部楼层
不知道!!!!!
GMT+8, 2025-12-25 13:35 , Processed in 0.030220 second(s), 6 queries , Gzip On, Redis On.
