楼主: dylan_uestc
[求助] 请教:运放偏置电路的问题
发表于 2011-11-6 16:29:26 | 显示全部楼层
When you first pick up the topology of the amplifier, you should have some idea what is the sensitivity of the supply/bias variation. Optimize your design with typical supply/bias condition and verify it still acceptable with process/supply corners. It's an iterative process anyway.
发表于 2011-11-11 14:17:21 | 显示全部楼层
顶一个!
发表于 2011-11-15 22:30:45 | 显示全部楼层
我觉得要看你要设计的精度了吧,对偏置的仿真和对运放的仿真都要做完善
发表于 2012-4-15 14:02:30 | 显示全部楼层
我觉得也应该先用理想偏置设计运放,然后设计偏置,请高手解释
发表于 2012-12-25 10:28:23 | 显示全部楼层
这个是要顶的~~~~~~~~~~~~~~~~~~~~
GMT+8, 2025-9-15 11:56 , Processed in 0.011980 second(s), 3 queries , Gzip On, Redis On.
