查看: 3666|回复: 0
[求助] 用astro创建ref library时遇到的问题
发表于 2010-7-23 21:40:58 | 显示全部楼层 |阅读模式
首先用auNLIApi读进去的lef文件,在布局布线的时候正常,但用read_lef读进去后,corner pad就不在角上了。我的lef文件是5.2版本的,antenna lef文件是5.4版本的,antenna读的时候出错。
然后用
auExtractBlockagePinVia
formDefault "Extract Blockage"
setFormField "Extract Blockage" "Library Name" "FSA0A_B_IO"
setFormField "Extract Blockage" "Cell Name" "*"
setFormField "Extract Blockage" "std/module cell" "0"
setFormField "Extract Blockage" "macro" "0"
setFormField "Extract Blockage" "pad" "1"
setFormField "Extract Blockage" "extract connectivity" "0"
setFormField "Extract Blockage" "Metal1 Text" "46"
setFormField "Extract Blockage" "Metal2 Text" "48"
setFormField "Extract Blockage" "Metal3 Text" "50"
setFormField "Extract Blockage" "Metal4 Text" "52"
setFormField "Extract Blockage" "Metal5 Text" "54"
setFormField "Extract Blockage" "Metal6 Text" "56"
formOK "Extract Blockage"
这里46,48这些是mel1,mel2的layer number,lef里面没有定义text layer number。
用tf 里面定义的text layer number提取出错。
有没有高手知道这些是什么原因引起的?
GMT+8, 2025-12-21 08:57 , Processed in 0.011804 second(s), 3 queries , Gzip On, Redis On.
