查看: 9121|回复: 6
[求助] Why the gain of first stage is greater than second one for two-stage op?
发表于 2010-7-7 16:49:16 | 显示全部楼层 |阅读模式
Why the gain of first stage is greater than second one for two-stage CMOS op amps?
Please explain it for me.
Thanks you in advance.
发表于 2010-7-7 17:18:41 | 显示全部楼层
noise比較低
发表于 2010-7-7 17:41:58 | 显示全部楼层
第二级可以用来提供较大的摆幅,不用cascode结构,所以增益比第一级低;
第一级增益大的话方便进行频率补偿,将主极点放在第一级的输出节点处;
有利于减小第二级的mismatch和noise
发表于 2010-7-7 18:31:08 | 显示全部楼层
no such mandatory requirments. Although it could reduce noise and psrr, it will make frequency compensation complicated. Trade-off considerations should be performed based on a specified envirement.
发表于 2011-6-11 22:06:32 | 显示全部楼层
学习了
发表于 2011-6-11 22:41:23 | 显示全部楼层
同学习。。。
发表于 2011-6-12 07:51:37 | 显示全部楼层
表示不理解
GMT+8, 2025-12-23 13:33 , Processed in 0.020827 second(s), 5 queries , Gzip On, Redis On.
